Safe One Wire energy transfer by Serbian inventor Milutin Miletic
Started by hartiberlin, June 16, 2011, 11:51:28 AM
FatBird
I wish some of these inventors would tell us how they work so we can verify it.
Quote from: FatBird on November 18, 2012, 06:32:20 PM
Well, he's got the drill motor, the light bulbs.... what more proof do you need, an electric heater? A fan? Some people are just never satisfied.
Quote from: lancaIV on November 19, 2012, 12:35:28 PM
http://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=20121031&CC=RS&NR=20110026A2&KC=A2
Sincerely
                 CdL
QuoteInvention herewith described refers to the safety electric power transmission cable. The insulation (2) should be placed around the voltage conductor (3) and the metal sheath has to be put around the insulation (2) as a grounding conductor (1).
Revolutionary! Why didn't I think of that!
stAtrill
Of course, that is back to the 'wire within a wire' idea. If that was the case, why not use just normal coax? There is also a problem with this idea: if you plate the wire solidly over the insulation sheath, you run the risk of delamination of the sheath or insulation or both - the wire would essentially be unbendable or it would fall apart. And whats more, is I am not aware of any process in the world that allows you to adhere metal onto a soft material (like any plastic/rubber insulation). The wire-within-a-wire was perfected with coax, which uses metal foil or mesh as the second layer.
I have a feeling this draws more from antenna theory than from circuit theory. Driven at the right frequency, you have a steel core coil with a secondary sharing the same core. You could tune that to be exceptionally efficient (and even with no tuning you should still show a voltage on your secondary). Looks like JLN did an experiment on this a while ago:
http://jnaudin.free.fr/meg/megjln01.htm
In his experiment, he did the same thing: two coils sharing a common core. He just happened to also test mounting a permanent magnet to the core as well.
Some food for thought.
