My Open-Sourced OU Project Using Ferrofluid (PICS)
Started by Dondeal, June 22, 2011, 05:38:28 PM
Dondeal
Quote from: Low-Q on June 26, 2011, 07:03:26 AM
You cannot choose in what direction the capilary effect will work. This effect will also prevent the fluid to exit the hose. No free lunch in this effect.
The fluid automatically flows through the lower tubing and sits there half-way through the loop (that is capillary action). The rotor brings the fluid over the loop and back into the reservoir through the top tubing, completing the process.
The fluid level inside of the reservoir is never higher than the upper opening so the fluid can never come back into the upper tubing.
The fluid does exit the upper hose. Remember, I built it and I'm doing that part right now.
Low-Q
Anyways, capillary effect is not energy and cannot provide energy into a system. In one way or another, the capillary effect will take back what it appearantly gives.
Dondeal
Quote from: Low-Q on June 27, 2011, 01:20:27 AM
I will post again when I finish the build and can show a video.
Reminds me of the magnetic gears concepts:
http://pesn.com/2010/07/14/9501672_Terawatt_Research_LLC_defies_free_energy_stereotypes/
You might be on to something. But you'll require an efficient turbine to get out as much power as possible.
http://www.gyroscope.com/d.asp?product=TESLATURBINE3
z.monkey
Howdy Dondeal,
Can't say that I have ever seen anything like what you are doing related to electrical energy production.  But I have seen it, well read about it, used in an artificial gravity system, like UFO propulsion.  By spinning a large, balanced mass you can produce a artificial gravity field.  Crude systems used large iron rings mounted on shafts and propelled by a diesel motor.  As the craft evolved they realized they only needed to move the mass and didn't need the large spinning apparatus.  The mass, in this case mercury, was pumped through pipes in large concentric rings.  When they turn the pumps on the mercury would flow through the pipes and generate a artificial gravitational field...
If you want to study this more look for information about The Raman Empire (ancient India), The Vedas, Vimanas (Raman UFOs), and any of the Nazi UFO information.  The Vimanika Shastra is here.
http://www.overunity.com/index.php?action=downloads;sa=view;down=124
Hydraulics, and Pneumatics are very useful, and if we can find a way to pump fluids with magnetism then you can pump fluid in a hermetically sealed environment.  That may be very beneficial.  Then that whole artificial gravity field thing would be a whole lot more beneficial.  I have a plethora of information available in the downloads section here on overunity.com if you want to give it a look-see...
Your fabrication skills look pretty good as well...
Good luck with your endeavor...
Goodwill to All, for All is One!
