Trawoeer Power Pyramid Version 12 - Electrical output from a homemade pyramid
Started by hartiberlin, June 28, 2011, 04:05:30 PM
gauschor
Please reconsider some parts of your theory with these hints:
1) The moon actually does spin.
2) If the "gravity" is a pushing force and comes out on the poles, how come people don't fly off or jump higher at these locations?
3) The expression "Pyramid" is greek and the name was given thousands of years later after the pyramids were built - the name was not given because of a "mysterious" power in the center, but because of the top of the pyramid which was made of brighter material gleaming in the sun, looking like a fire from afar. The name is purely superficial and does not explain any deeper background.
Unfortunately I can't recall the original name of the pyramidal structures anymore, and which book it was that explained in more detail.
duff
HI Ben,
Thanks for the paraphrase -
I don't know if you read the entire post but he presents a background discussion prior to the theory.
Also thought you might be interested in this comment concerning wood construction.
Quote from: Thomas_Trawoeger on November 23, 2007, 06:54:09 AM
@freecell: I tryed to build the pyramide with copper-tubes, but it didn?t work proper. (I don?t know why)
As i changes the construction into wood, it worked absolutely not, because there was no minus pole.
EDIT:    Concerning Wire
http://www.comshop.tv/tpp/community/index.php?action=view&topicid=11
   Trawoeger (08.07.2011 08:30):
Hello
I never had sucsess mith multi-strandes wires. I don´z know why, but maybe there is some turbulence inside the wires. You can use the thicker Wire too, but you have to calculate the outside coil and the capacitor depending to the inner coil.
The Formular will be shown here on the next days.
Edit2:
http://www.comshop.tv/tpp/community/index.php?action=view&topicid=12
Trawoeger (11.07.2011 09:38):
hello
Well, i use steel with a diameter of 20 x 20 mm (of course hollow with a thickness of 2mm)
(very cheap and everywhere buyable in the mm-zone)
Everything is welded good.
You can use copper as good as Steel, but my working skill did better effects in welding steel as in soldering copper :-)
k4zep
Quote from: duff on July 12, 2011, 07:39:22 AM
HI Ben,
Edit2:
Thanks Duff for giving me the heads up on the wood idea of mine and it not working!!!!!!!!  Arrrrgggg, there goes that easier build!!!!!
Hope we all can keep each other on the "right" path to get this thing to work!!!!!!
Ben
Trawoeger
Hello Community
I want to say Thanks to you, that you try my Device practically (we spoke too much the last days..)
Off Course, I was silence reader of this thread since the beginning, and now, we will have the great chance to prove V12 in more countrys.
But I have to say it very clear: Pleas follow all the steps as described.
It is very important now, to get the first POSITIVE Results without any experiments, because if you have a running pyramide, there would be plenty of time to make experiments.
The Major Problem will occure, if the first guys will haave a non working skulpture in the shack..
To provide this, please follow all Steps as described.
I had so much problems with measures und coils, I cant count.
And if i could understand all the Process inside the Pyramide, i could tell you all about it.
But now, I can only reproduce my V´s, and believe my, I am still stunning like a kid :-)
The last days, i tryed to get some Coppertubes with inches instead of my tubes in Millimeters, to check the necessary measurements. I also tryed to get the cables with non european Norms, but there is no way for me, to get something.
I think, there are very important differences and maybe some new calculations necessary, to get this to run.
To make shure, we will have a working V12 in overunity.com too, you can vote for a member of your desire.
If this member of overunity.com want to make the V12, i will send him all the inside Material (reactor, sand and capacitor) on my Costs to make it running.
I want you to decide, who will get this, because i don´t want ´bad ideas (And Yes, I will pay nobody for good results :-)
I make the same deal with somebody in the german Forum: His name is "Freigeist" and he is the only guy in the whole OU-Scene wich gave more than words to this case.
(The guy made the complete V12 Tutorial in german Language!!!)
So if we would have 3 Guys around with a working V12, we would have a good platform for further research...
You can decide, who´s the guy, but don´t vote for Yourself....  ;D
I would be happy with some real integrated Person here, and it is not necessary to be a fan of me :-)
You can send your vote as PM or to  tpp-et-comshop.tv
Nice greetings
Thomas
