Trawoeer Power Pyramid Version 12 - Electrical output from a homemade pyramid
Started by hartiberlin, June 28, 2011, 04:05:30 PM
k4zep
Hi Gang,
I had a very productive talk with Thomas this morning that cleared up all the questions
I had about the unit.  It was just a bunch of small things that I had to clarify from the video
but nothing that wasn't already shown in his series of videos.
Spend all day working on Reactor, trying to solve an engineering problem.........will have to make it.
Tomorrow will load and charge and see if I have a working unit or not.  IF it shows signs
of life, will show pictures of it.  Luck to all the others that are working on this device!.
With the size of the wire (#16 TW), I had a hell of a time getting the 87 turns specified by Thomas on the central core but
I finally got it in with no shorts, etc!  Have to wind the matching 87 turn coil on the outside form but that can wait till
I see if the main reactor shows signs of life after the charge procedure.  I'm going to use about 7.5KV AC to charge it.
Slowly we are getting there.  I expect others will finish and have a operating unit before I do, not to worry,
this is a very personal challenge.   I just want to see that 10 watt light bulb light and/or that motor run!  It will make my
decade!
Respectfully
Ben K4ZEP
energia9
peter markovich 1977,   the connections seem to be very very similar.
can someone ask trawoeger if he has copied from this guy because the connections seem to be nearly the same and the setup is 90% the same.
this guy drew 500 watts woooooww!
Pascuser
Quote from: k4zep on July 18, 2011, 10:33:46 PM
Hi K4zep
Good luck!
Why did you wind 87 turns and not 97 turns like he said in his videos? (is it the same dimensions for the reactor you designed?)
k4zep
Quote from: Pascuser on July 19, 2011, 05:41:35 AM
Hi K4zep
Good luck!
Good Morning Pascuser,
In part 3 of the video he did say 97 to 105 turns.  Yesterday, in conversation with him he said 87 turns.  I am awaiting clarification.  I only wish I could talk so well in German as he does in English!.  I think  both numbers might work if the outer coil matches the inner coil with resultant difference in voltage and current but again, just a WAG theory right now.  Right now my test coil has 87 turns.  I suspect my coil will be a lower voltage, higher current unit.  Again this is my first try with a reactor using "Inch" sized parts.  Mostly a exercise in how to do it while awaiting parts from Thomas.
One other thing I cleared up yesterday is the question of the small fan that he uses when he starts the reactor up.  It is a STANDARD
12 VDC computer/ventilation fan.  Nothing more nothing less.  Not a critical part but I didn't know the specifications on it.  He did say not to use a 5VDC fan as it would likely burn up when the reactor kicks in.
Respectfully
Ben K4ZEP
ElectricGoose
Quote from: k4zep on July 19, 2011, 08:08:13 AM
Respectfully
Ben K4ZEP
Ben
I was not going to say anything but the 87/97 turn discrepency isn't the only thing twisting in the wind here.
As you say, the number of turns does NOT matter and will only effect output.
However,  I have held my tongue until now on something else... but you might want to ask Thomas....is he 100% sure it is AC you apply to the reactor?????  That just doesnt make sense.
1)  Thomas himself said in the video "HOT (+) to centre and Neg (-) to outer.  Thats more than likely DC!!
2)  Besides...If you want to align the polarity of ANYTHING (essentailly making a free energy tuned electret)....AC would be useless!
But hey....if it's AC and it works...then so be it!
Just trying to save you some work.
