Trawoeer Power Pyramid Version 12 - Electrical output from a homemade pyramid
Started by hartiberlin, June 28, 2011, 04:05:30 PM
zhak
neptune
Hi Zhak , nice pictures . It looks like you got your turner or lathe man to modify some off the shelf fittings . Are you in the UK ? Are the finished end caps a fairly tight fit in the large copper tube ? To help others , could you please tell us where you bought these fittings , what they are called , and the approximate cost please ?
zhak
Hi
I live in Russia, Sochi
Fittings - Hose adapter is 3 \ 4 (brass)
Turner it shortened, changed the diameter of the inner and outer
Cost $ 1x1, on the iron - clothing market.
But like you can buy in store.
croco31
Hi zhak (from France),
i have started the process of procurement of copper tubes, sand etc.. some work for this WE.
Have you foreseen some mean to locate a point on the ground above river line to make the pyramid working?
When finished, i intend  to try the reactor alone with a microammeter (old analog one: no electronics, 20µA range DC) connected to the inner coil side an through the outer coil (same as final scheme).
If something is collected from earth (i assumeTPP reactor works), by walking around as a pendulum it sould be possible to detect a (maximum) signal for the pyramide best position.
Any suggestions ?
Thank you
Kind regards.
croco31
zhak
I have a river near there!
I'll look under the ground (there is even such water in the desert)
method lozohodstvo
http://ru.wikipedia.org/wiki/%CB%EE%E7%EE%F5%EE%E4%F1%F2%E2%EE
