Trawoeer Power Pyramid Version 12 - Electrical output from a homemade pyramid
Started by hartiberlin, June 28, 2011, 04:05:30 PM
0 Members and 23 Guests are viewing this topic.
gegyx
hory
Hello Everybody,
Has someone noticed, what Thomas said, and did in the video? He said that in the reactor the inner and outer coil shold have wound in the same direction(cw and cw, or ccw and ccw). I watched the whole movie many times, but I think he wound the inner ond outer coil in opossite direction. (inner:ccw, outer:cw)
Regards.
d3x0r
I have some stuff :)
http://www.scribd.com/doc/77496863/TPP-Replication-1-0
I got a new meter that can measure farads, so measuing these two coil caps, they are 492-498
(yesterday) to 500pf(today both).  call them 500 for grins.  And they are nearly identical
depsite being 10m and 11m of wire.
My coils are
3mm wire diameter(with insulator)
96 windings each
261mm length of coil
inner coil is...
9.8mm (core it's wound on)
12.8mm (diameter at center of conductor)
15.7mm (diameter measured outside conductor)
outer coil is...
42.1mm (core it's wound on)
44.85mm (diameter at center of conductor?)
47.6mm (outer diameter (on electircal tape?))
so that would give the inner coil...
3.2uH(inner diamter)... 5.5uH(conductor)...  8.3uH(outside)
that would give my outer coil...
57.4uH(inner)... 64.9uH(conductor)... 72.8uH(outer diameter)
that results in a range of 60.6-81.1uH
with an average of 70.4uH
according to my signal generator pumping the circuit at 1.133Mhz (http://www.whatcircuits.com/lc-resonance-frequency-calculator/ ) the coils would be 78.93uH at 250pf (with caps in parallel)
Going the other way knowing the capacitors and calculated uH I can get kHz
790.359khz - 914.321khz (using one capacitor 500pf)
1117.73khz - 1289.8567khz (using both caps in parallel)
turns out that if I connect my scope to one of these capacitors and put my hand on the capacitor and turn the sensitivity way up, I get a strong frequency about 1.2Mhz...( I guess this the the AM station that comes in pretty string on 1230AM)
Is there really 2.5watts or something one can pick up with a cone/pyramid antenna on an AM oscillator?
Also TT didn't go into much detail on what high voltage is, I found from research that his was a 5KV transformer, but was he running that off of straight AC?  so it was a 50Hz wave?  If I get an ignition coil and drive it with an audio amplifier with my signal generator with a square wave and can get 30KV(or so) is that enough?  how many amps is it? do amps matter?  What is ther pecentage of magnetite in his sand?  Mine is high enough that a cup full or so will get a small amount collected around a magnet in a plastic bag....  If I used this bashar coil (a conical coil with wide frequency responce characteristics) would I harvest more than a single band of AM at a time? Sorry I'm starting to diverge.
http://basharspacetimeantenna.files.wordpress.com/2011/02/joakims-antenna.jpg
(links I may or may not have included)
coil inductance calculator
http://www.66pacific.com/calculators/coil_calc.aspx
lc circuit
http://www.deephaven.co.uk/lc.html
