Trawoeer Power Pyramid Version 12 - Electrical output from a homemade pyramid
Started by hartiberlin, June 28, 2011, 04:05:30 PM
fritz
Quote from: Jimboot on July 02, 2011, 05:11:22 AM
I'd like to make a small scale one first but I am finding it hard to source hard drawn copper tube in lengths shorter than 6 meters. Anyone have a good online supplier that will deliver to Australia?
Maybe the shipment costs as much as the entire 6m tube ;-))
Here in _AUSTRIA_ - you get them in 2.5m length in every DIY market.
So maybe the best option would be to find other willing replicators in Australia - and cut the 6m piece down (already in the shop).
Another problem I expect - is that if you don´t use the same brand wire - the insulation might have quite different dielectric properties (which is not specified for this wire). This means that the necessary wire length for the capacitor might be different - and the even the entire setup might not work - or different. Both coils for kind of LC tanks - the "C" be different either.
neptune
@Jimboot . Why not phone your local plummer and ask if he has any offcuts ?
Jimboot
conradelektro
Quote from: e2matrix on July 01, 2011, 02:40:21 AM
Hi Conrad,  PK's book is one of the best on the planet :)  2200 + pages for download : http://www.free-energy-info.co.uk/PJKBook.html
@e2matrix: thank you, I downloaded the book, looks very good
@a.king21: I read the pages (chapter 7 pages 1 to 12), very interesting, I will try it one day, thank you for bringing this to my attention
Greetings, Conrad
AbbaRue
By water lines I believe he is referring to the Telluric Current grid.
Here is a link with some maps.
http://www.nap.edu/openbook.php?record_id=898&page=232
Maybe someone can find a better closeup map.
Or using a quad amp chip and few other components maybe we can build an energy field detector to find them.
The use of divining rod may not be far fetched, where these grids cross does contain a concentration of energy .
A simple set can be made with 2 pieces of copper tube you hold in your hands,
with a 90 Deg. angled piece of bare copper wire placed in each one, so they can turn easy in the tubes.
The way you use them is: you hold them in your hands so the 2 wire's ends are perfectly level,
one a little higher then the other and as you walk around the 2 ends will cross each other
when you find one of these nodes.  It's an easy thing to test for your self.
