Trawoeer Power Pyramid Version 12 - Electrical output from a homemade pyramid
Started by hartiberlin, June 28, 2011, 04:05:30 PM
ElectricGoose
Quote from: k4zep on July 05, 2011, 07:08:58 PM
Hi All,
I sure wish there were a way to ask the good German fellow a few questions to clear up some fine points in his videos.
Ben K4ZEP
Hi Ben
Not sure what you need to ask TT...everything was pretty crystal clear really.  Those 'tuning' coils act more as a capacitor than anything else, that's why only ONE end is hooked.
Let me save you some double work.  Whatever you do, DONT use magnet wire.  The dielectric will crap out during the charging process as you have suggested.  I think TT has been a little bit hasty in his guestimate of requiring a 15kv oil ignition xformer.  I ran some tests with high quality insulated wire of the same size wound on copper and the insulation started to fail at around 4kv DC (only 15watt input)....my own high voltage setup.
I think 1.5 - 3kv is more than ample.  You only want enough charge to align the quartz domains.  It's basically a big scalar crystal receiver.
Regards.
k4zep
Quote from: ElectricGoose on July 06, 2011, 02:01:08 AM
Hi Ben
Regards.
Morning EG!
Thanks for the info, you are absolutely correct that the video is VERY complete, not being picky but just want to have all the ducks in a row and sort out everything before I start a build.  I pretty well had decided that there is no way standard home wiring, THN, THHN etc, could handle 15KV from previous experiences and would break down.  I have a Variac so I can control my output no problem, have a 7.5KV furnace and a 15KV neon sign transformer, plus a 2.5 KV AC switching power supply.  HV probes, to measure.  It is unique that there is physical alignment of the quartz domains and as you say probably a scalar receiver. He seems to say that it is DC output but the scope shot shows a pulse output and I suspect that is a AC fan motor, internally rectified to dc.  Again a slight unknown variable.  Another thing, THomas said that metal was not important in the Pyramid (another member noted that it was built of Steel 5 years ago, and looks that way in the welding spots) but all pieces had to be electrically connected, and he did run it with a ground at first but after he got it working, he took off the ground at the very end.  I think he insinuated that a static field can build up on it and shock you and hence the ground is needed while working on it......another variable to look at.
Has he ever built a smaller unit?  I live in a condo and will have to transport it around with the elevator/trunk of car unless I can pick up on a hot spot 6 stories up.   A .5 to .75 meter unit sure would be more manageable unless I can break it down for transport but only 36" doors out of condo.   There is a nice open field only about 2 miles from where I live to test in/film/etc.
Last night, went to PetsMart and look at aquarium sand.  Pretty fine stuff, can get what looks like fine black quartz or tan quartz but doesn't say that's what it is for sure, WalMart, looked at play sand, too many different size crystals in there, going to pool supply and look at filter media, Probably what I will get as it is screened/sized for best filtration and that is what Thomas says to use too.
Picked up where Thomas said that the walls of the Pyramid HAVE TO BE A MINERAL  Said very important.  Hummmmmmmm, even if I use thin Sheetrock, this sucker will still be heavy......Always something to work with......Wonder if a thin skim coat of tile cement would work over 1/2 foam.....sort of like stucco on  a house.  First, got to get something working true to his build......then can experiment......
Another day, stuff to do, retired, keeps me busy!
Respectfully,
Ben K4ZEP
neptune
Hi Ben . As you may know , I am not a big believer in water divinig , but having said that , I am open minded . I want to encourage you in this replication , as I have done in the past . Re sand . Avoid play sand , as I have been told it is powdered limestone . This sand is vital . Get it wrong and the whole thing becomes a waste of time . Personally . I would start by building the reactor . That way , you can tackle the 2 biggest mysteries first . If you can "treat " the sand with RF or high voltage , and then get it to pass the multimeter test shown on the video , you will feel happier to build the pyramid . I still feel you would be better with a collapsible full size job than a smaller version . I like your mineral coating idea , but as you say ,this is an experiment for after you get a working model . Learn more about sand . Google it , perhaps . Good luck with your experiments , and keep us posted .
k4zep
Quote from: neptune on July 06, 2011, 09:15:34 AM
Thanks Neptune,
Have my order ready for the copper @ McMaster Karr but going to Lows and Home Depot and see if I can get the half hard rigid tubing there first, then might try Castle Plumbing Supply.  Don't know about the adapters, might just use end caps and center drill them in my little lathe.  Then solder one end.  Should be fine.
I do know dousing works for me, have found buried wells, artesian wells, buried submersible  well that was lost and pump stopped working for a neighbor about 20 years ago. shesssssss and I am the most skeptical, or a show me kind of person. I can NOT explain it, you just think "water" and walk around and it works......First well I ever doused was on my fathers land 58 years ago or so, found 3 good spots, dad told the drillers here, one of my spots, their "dowser" (yes, they used a dowser too! another old geezer) said, very good spot too, drilled 10 feet thru clay/sand, 65 feet through blue granite, drill dropped 10 feet and will artesianed for a day and settled down 10 feet below ground level after pumping it down with huge pump, could only draw it down 5 feet.  Best water I ever drank!  Strange story but true.  Checked about 5 years ago, well is still there in front of house dad built.
I always used a live "Y" from a apple or peach tree but have used crossed wires, don't like them as much.  Believe it or not but it will twist the bark off the "Y's" over a strong point when trying to point down.....Yah, I know sounds honkey.
Anyway, keep any input coming, any ideas, thoughts, I realize this is far out, but going to try it! How this device can draw energy from these areas is beyond me.......Feel like I am watching "Fringe" live! Onward!
Hummm.  If those crystals can be a receiver, wonder if they could be used to build a transmitter?  Thinking out loud.
Respectfully
Ben K4ZEP
k4zep
Hi All,
Have filter sand, looks good.  Have all tubing ordered, have sources for all materials, 1/4" gypsum board, etc.  Now have to wait for material to come in.  Home Depot, Lows, WalMart, PetsMart, no go for stuff.....but OK, found it all.  Just takes a little time.  Will build reactor first. try HV first, see if it passes the first test, then build pyramid last.  Be back with pictures when stuf comes in and build progresses.  Might go looking for hot spots tomorrow.....All in due time.
Ben K4ZEP
