Trawoeer Power Pyramid Version 12 - Electrical output from a homemade pyramid
Started by hartiberlin, June 28, 2011, 04:05:30 PM
k4zep
Quote from: nul-points on July 12, 2011, 06:28:22 PM
me too, if Ben is agreeable
my only worry is if Ben 'Strikes Water' whilst working in the "World's Smallest Lab", will he be able to get out in time and shut the door before he sinks the Condo?  ;)
Don't worry NP, I got it covered with my "noodle"...................going to float my boat.
Let me say folks, I am really serious about the Pyramid power.  So lets see what happens......
The picture below is just for fun!
Respectfully
Ben K4ZEP
believe-it-when-i-see-it
Hi all,
What do you make of the mention of copper and power within this recent CNN article about the Great Pyramid of Giza? .... particularly
"The camera also scrutinized two copper pins embedded in the door to the chamber at the end of the tunnel. In a statement, Shaun Whitehead, of Scoutek UK, said: "People have been wondering about the purpose of these pins for over 20 years. It had been suggested that they were handles, keys or even parts of an electrical power plant, but our new pictures from behind the pins cast doubt on these theories."
http://www.cnn.com/2011/WORLD/africa/05/28/pyramid.markings/index.html
and to a lesser extent in the following (no mention of copper in this latter short article):
The Power and Mystery of Pyramids
by
Dhyani Jo Sinclair
The meaning of the word pyramid is "fire in the middle," derived from the Latin pyra (Greek pur ), meaning fire or light. What is this fire in the middle and how is it created?
A pyramid structure, with closed or open sides, creates a vital centre of electromagnetic energy if it is constructed to the same proportional dimensions as the Great Pyramid of Giza and if one of its straight sides is facing true north. As long as the pyramid is aligned to the north-south magnetic axis it will become "charged." The space within the pyramid accumulates and intensifies energy, generating an energy field with unusual properties.
Since pyramid power is only created when a pyramid's angles and ratios match the Great Pyramid, let us first investigate some of the marvels and speculative history of this first and only remaining "Wonder of the World."
The Great Pyramid of Giza
source: http://www.pyramidyoga.com/infopages/why-pyramid.htm
Trawoeger
@all:
It would be a pleasure for me, to work with Mr. Ben (K4ZEP) because he is (in my opinion) absolutely thrustful and i think, he will have the reputation here to proof something. And of course, his working skill should fix all the little problems...
(I checked the possibility to send the necessary Parts from Europe to US, and it would be not the great thing...)
Today i spoke with a good friend wich is working on a great forewarding Company. he told me, the Americans are a little bit paranoid with unexplainable things in Packed goods, but we could declare all goods as Parts for Antennas specially for HAM - Users....
Its good to have a HAM on the other Side  ;D
73 de OE5TRP
(For all non HAM´s - nice greetings from Tom)
Pascuser
Quote from: Trawoeger on July 12, 2011, 11:09:40 AM
The last days, i tryed to get some Coppertubes with inches instead of my tubes in Millimeters, to check the necessary measurements. I also tryed to get the cables with non european Norms, but there is no way for me, to get something.
I think, there are very important differences and maybe some new calculations necessary, to get this to run.
That's a bad news for my replication in scale 1/2 nearly achieved with screw and bolt. I live in Europe (France) but since 1 meter side is a big pyramid (and heavy to carry) I built a 50cm side pyramid and if no calculations are possible I will not be able to build a working reactor.
What's more the following question was in my head since few days:
I wanted to divide all sizes in half in the reactor; with the question: if I reduce the coil in half measurement (the double coil in the reactor, with the sand), its inductance will be reduced by half (diameter half, length half and number of wiring the same with a wire half diameter gives half inductance) and the capacitor will be half only if the distance between the plates is divided in half too (you have to find a half thinner isolating plastic around the wire, assuming it is the same dielectric value).
Then you have a resonant condition with L and C. Let's say that the frequency is tuned to the size of the pyramid. The energy from the ground goes in the pyramid frame and a waveform is generated. This I deduce from other studies about the use of Cosmo tellurism in forms. The length of the wave generated is connected to the pyramid size. So the pyramid size is half, and the wave length is half.
But a resonant condition in LC circuit gives a resonant frequency depending on L*C product. So if L is half and C is half then L*C is quarter and is not tuned to the waveform which is half. It is only presumptions but this is a link between a flow of energy which is continuous coming from the ground and the fact that we tune to a frequency: this energy coming from the ground vibrates within the form of the pyramid.
So you have to take half of the coil inductance and not changing anything of the capacitor if you want to stay tuned with a half pyramid.
Maybe these ideas can help you in modifying your specifications within the reactor to have it working with scales!
I have to build a 1 meter new one now!
To make shure, we will have a working V12 in overunity.com too, you can vote for a member of your desire.
If this member of overunity.com want to make the V12, i will send him all the inside Material (reactor, sand and capacitor) on my Costs to make it running.
I want you to decide, who will get this, because i don´t want ´bad ideas (And Yes, I will pay nobody for good results :-)
Very good idea! This is important to have an independent replication working. There is skilled people working here and somebody will be elected for sure.
Meanwhile I must build a new pyramid!
nul-points
Quote from: k4zep on July 12, 2011, 08:02:19 PM
Respectfully
Ben K4ZEP
Ben, that's what i admire about you - prepared for every eventuality!  :)
good luck with the replication
