Trawoeer Power Pyramid Version 12 - Electrical output from a homemade pyramid
Started by hartiberlin, June 28, 2011, 04:05:30 PM
Pascuser
Quote from: madsatbg on July 16, 2011, 01:37:59 PM
How to Finding the intersection of Hartman's network?
For now, no positive result.
Very impressive work; very beautiful pyramid. I wish mine be as beautiful.
To help you finding yourself your water lines and Hartmann lines so you can put your pyramid on a node:
Detecting water line:
1) How you can use L rods to find a point above an underground water line, amateur work (you usually don't keep rods in your hands like him but it worked):
http://www.youtube.com/watch?v=KeRCcFB66fU
2) And now a lesson: how to use rods, how to carry them in the hands, and how you can trace a water line with it and finding depth of water:
http://www.youtube.com/watch?v=h_zsLyBr920
3) How to build your own L rods cheaply:
http://www.youtube.com/watch?v=0R6moIY3pjA
Detecting Hartmann lines:
I did not find anything valuable in english but I have a good website in french. I give here links for an automatic translation with google translation (poor quality but you could understand something):
1) Prepare the work:
http://translate.google.fr/translate?u=http%3A%2F%2Fwww.conscienceverte.fr%2Fa-la-preparation-2-90.html&sl=fr&tl=en&hl=&ie=UTF-8
2) East-West detection: use previous link in the left menu (section B)
3) North-South detection:  use previous link in the left menu (section C)
4) My work in my garden: a practical demonstration of use
The water line I detected: each red painted wood on the ground is a measurement point; where my L-rods cross: the painted side of the wood is put on my right when I walk. I made 4 measurements walking in East-West and 4 in the reversal way West-East and so there is 8 measurements points each time. The big wood rod is put in the ground in the middle of the points each time to have an average. It is pretty accurate:
http://nsm05.casimages.com/img/2011/07/03//1107031239531203828416933.jpg
Now I searched for the Hartmann lines:
http://nsm05.casimages.com/img/2011/07/03//1107031239591203828416935.jpg
The wood rods in the garden are the water line detected with L-rods
The small woods with red painting are put on the ground each time my lobe antenna rotated (100 measurements done) to find Hartmann lines.
I have a node where Hartmann lines crosses the water line, I marked it with a cross on the ground.
Anybody (almost anybody, some people seem not being able, but few) can do that.
A schematic of my garden findings: in green you have hartmann lines and in blue you have the water line and nodes are pointed with a cross: main node in water line and secondary nodes: only Hartmann lines crossing:
http://nsm05.casimages.com/img/2011/07/03//1107030151061203828417138.jpg
You can build yourself a lobe antenna with a brass heavy wire.
Now you can do it yourself!
But if you want somebody having powerful capacities to find a powerfull source of emission(because when you find a node it has a strength, depending on the strength of the water line); you should hire a professional dowser. They use their tool in another way than I do: they use them to ask questions. I don't understand how it works, but it does.
Here what a professional can do:
http://www.youtube.com/watch?v=VrrN6UYZj38&feature=relmfu
Thomas used profesionnal dowser to find the nodes for him and used many to compare results and used powerfull nodes that every dowser found.
k4zep
All,
Read this link and know it well.  It will become useful when you set up your Pyramid.
http://en.wikipedia.org/wiki/Magnetic_declination
In one of his videos, Thomas mentioned his pyramid was about 2.5 degrees offset from magnetic north for best output.
The question of orientation of the pyramid is as NP said, the back of the three sided pyramid should FACE N +/- a few degrees
based on the composition of the earth beneath the pyramid (just a theory right now) when I can test it, I will know for sure.
Respectfully
Ben K4ZEP
nul-points
Quote from: k4zep on July 17, 2011, 02:03:04 AM
...orientation of the pyramid is as NP said...
Ben K4ZEP
i'd like to take the credit...  but i think it was Neptune!  :)
NickZ
  I find that when the pyramid is inside the house, or garage, it can be off by a couple of degrees from Magnetic north, due to the metal re-bar in my walls, the metal roof, and metal reinforcements in the floor.  There can also be other reasons for the differences of a couple of degrees.
   I agree that the best place to put the pyramid is on a node, outside of the house.  I am also a dowser, and can find those points, but please explain what are the other lines that are mentioned before.
   There is a lot of information about pyramid related topics in the Pyramid Thread in the Energetic Forum posts.  If you find it by searching for it, in their search bar. I don't want to confuse the purpose of this thread, as this is for builders instead of talkers,
like me.
Trawoeger
@K4ZEP: Thanks for your work.We will see us Monday afternoon (my time) to discuss all the following steps.
