Trawoeer Power Pyramid Version 12 - Electrical output from a homemade pyramid
Started by hartiberlin, June 28, 2011, 04:05:30 PM
Pascuser
I finished the reactor and assembled it inside the pyramid. The pyraid was put over a telluric node in my garden I detected myself, and correctly aoriented to north with some degrees more in east; with a level so compensating so it be horizontal.
I bought a 35W Ham Cb amplifier but it was destroyed in 30 seconds, in preliminary tests, before I used in on sand. So I had to find another solution. As I do electronic works sometimes I have some equipment. I used my signal generator with an amplifier able to deliver 10 Watts for a frequency between 4MHz to 13MHz. I used 10MHz.
First, the electric field measured when the amplifier is operating, while the sand has been filled (and when finished); measurement between the outside tube (mass) and a wire in the air at some distance (like Thomas did to prove the electrification of the coil): I read 238V with AC voltmeter (you can see the power supply that delivers 24,8V with 1,58 amperes to the amplifier. The amplifier use 0,33 amperes to power a cooler fan so it sucks 31 Watts for the high frequency production).
Then I used the same AC voltmeter to measure the voltage like Thomas did between the outside tube and the down wire of the coil, through my body. I find 1,31V.
I thought that all was OK. But I finished the correct mountinf of all components and when cutting the wires of capacitor there was nothing on my voltmeter. There was first no static charge inside and when plugged the voltmeter displayed 0,00 mV before, during or after cutting.
So I did other measurements; and I found out that I can have 1 volt or more with the wires in the air on my desktop, altough my computer was shut down; and nothing connected to the reactor. What is displayed (in AC) is completely irrelevant. My 1,31V were not a voltage between the coil wire and the tube through my body but was the same voltage (approximately) than with no connection from my wires to the reactor; in the air.
I used another cheap multimeter, but in AC there is only 600V gauge so I displayed 0V but I can't know. My first multimeter is a good one and works well; but I can't trust it as to know wether the sand is electrified correctly.
You, who did the same work to electrify the sand, did you test that you did have no voltage at all with the same multimeter, unplugging the wires from the reactor, and just being at the same place; so you really have a true reactor voltage and not some voltages created with the high impedance of the multimeter because of induction caused by ambient AC 50Hz (or 60Hz for USA)?
A question for Mister Trawoeger: could you please give me the name (references, mark and number please) of your ham CB amplifier so I can buy one that will not be destroyed in 30 seconds (I feed it with a ham CB 3 Watts output in 27MHz band). Yours has worked and I would want to do another electrification of the sand through a working amplifier like yours.
Thank you for this information.
Trawoeger
@pascuser:
I think there are many small, but in summary existencially errors in your installment.
I will check allyour thread messages to collect as many informations and i will give you my ideas in the following hours.
But i think,the proportions inside your Pyramide aren´t correct. So it can be,that your Reactor is to great in relation to your pyramide. Inside the pyramide,everything is working with frequenzy and electronic harmony.
Thats the tricky point, and that will make it heavy to run your non-scale device.
But i will keep an eye about you,and i want to make a "fast replication of your V12 to find my answers in the next hours.
We have very bad weather today in austria, and so i can´t make my last Outdoorvideo.
So i will make some experimentsin scaling down...
Please be patient,i willgive you my opinion in the next hours..
ng,tom
Pascuser
Thank you very very much mister Trawoeger!
I wait for your work with great excitation. I will be patient, no problem about it.
If you ask yourself a question about what I did in my system, the whole thing is fully developed in my forums; in french, sorry. So I put here links with an automated translation (in english for everybody and german for you). There are two pages where all is explained with pictures. Translation will not be good, be good enough ti understand what I depict and pictures explain things.
Building, first page:
in english:
http://translate.google.fr/translate?u=http%3A%2F%2Fwww.conspirovniscience.com%2Fforum%2Findex.php%3Fshowtopic%3D734%26view%3Dfindpost%26p%3D19235&sl=fr&tl=en&hl=&ie=UTF-8
in german:
http://translate.google.fr/translate?u=http%3A%2F%2Fwww.conspirovniscience.com%2Fforum%2Findex.php%3Fshowtopic%3D734%26view%3Dfindpost%26p%3D19235&sl=fr&tl=de&hl=&ie=UTF-8
Building, second page:
in english:
http://translate.google.fr/translate?u=http%3A%2F%2Fwww.conspirovniscience.com%2Fforum%2Findex.php%3Fshowtopic%3D734%26view%3Dfindpost%26p%3D19255&sl=fr&tl=en&hl=&ie=UTF-8
in german:
http://translate.google.fr/translate?u=http%3A%2F%2Fwww.conspirovniscience.com%2Fforum%2Findex.php%3Fshowtopic%3D734%26view%3Dfindpost%26p%3D19255&sl=fr&tl=de&hl=&ie=UTF-8
Three points to add:
First two ones are about the reading when cutting wire at the end of capacitor and the third about the reading of sand electrification.
1) I cut the wire of the capacitor while the voltmeter was plugged on the poles of the capacitor/coil reactor. Nothing is detected on the voltmeter (DC): 0.
My video (in french, but vocal is not important since I explained here what I did):
http://www.youtube.com/watch?v=aQGyaXp1fQ0
2) I cut the wire of the capacitor while the voltmeter was plugged on one pole of the capacitor/coil reactor and the other one is plugged to the ground frame of the pyramid, connected to earth with a wire.
Then I can detect a reading (DC). But this is a measurement not between poles of the reactor.
http://www.youtube.com/watch?v=IN8oIJtwDAQ
But this is not what you did mister Trawoeger, you plugged between two poles of the capacitor for measurement.
3) The measurement problem: what can I trust when measuring with multimeter to know wether my sand is correctly electrified?
If there is no real electric contact (measurement between copper tube and wire coil has no electric contact) then you can measure everything, because of electric AC 50Hz in the air that is displayed with the big input impedance of the voltmeter in a voltage that has no meaning. See here my video:
What can I trust to know that my sand has been correctly electrified? After having finished the sand electrification, When plugging one wire to the down wire coil and the other one to the outside copper tube I found 0,6V and with my body in series in the circuit I found 1,3V.
Now here I tested with no connexion with the coil, only with the copper tube (inside one but it is the same since inside and outside tubes are soldered together) and I can read a voltage too. And with my two wires not connected, I can have a voltage too. So what can I trust to know that operation was correct with the sand.
Did you get the same reading problems with your multimeter and the sand?
My video (in english with explanations inside):
http://www.youtube.com/watch?v=aWgscVRubFU
neptune
@Pascuser .I am sorry to see that you are having measurement problems and finding it hard to prove if your sand is "conditioned "or not . You could try testing in your garden away from mains electric wiring .Sorry also to hear about the short life of your amplifier . These amplifiers are a simple circuit , and perhaps you could fit a new transistor .But that will not solve the problem that this amplifier does not like a bad SWR . Maybe a good idea would be to use an Antenna Tuner [ called also a matcher or transmatch ] so that the amplifier "sees" a good SWR .You could make your own using two variable capacitors and a coil in the form of a Pi Network .Although this would be better for the amplifier , I do not know if this would result in less RF power at the reactor , but I think it would not .
    I personally think that the high voltage method of sand filling would be cheaper , but more dangerous . Thomas says a maximum voltage of 3Kv AC , so I think a microwave oven transformer giving 2 to 2.3 Kilovolts would work OK .These transformers are dangerous as they are capable of high current , so you need to know what you are doing . I would use some "remote controll" way to actually pour the sand .That way you can stay 3 metres away during the process .Hope this helps .
NickZ
 I would think that the reactor can be outputting 1.6 to 1.8 volts on its own, as it is very similar in more that just appearance to my capacitor can beach sand-cement cell, which outputs the same voltage when it was first made.
Just try another meter yet,  but I would think that the bigger meter that is showing some reading is the right one.  What do you get as far as current readings off of just the reactor?
