Trawoeer Power Pyramid Version 12 - Electrical output from a homemade pyramid
Started by hartiberlin, June 28, 2011, 04:05:30 PM
neptune
Hi Zhak . I think you are confused between the winding of the REACTOR and the CONDENSER .
1THE REACTOR  has 95 turns on the inner copper tube , and 95 turns on the outer plastic tube , both coils wound in the same direction .
2. The CONDENSER which is wound on a plastic rod [ Thomas calls it a wheel] . It has two coils wound on it , one an top of the other . Each coil is made from a piece of wire 11 metres [not 10 metres ] long . The first coil will have more turns than the second coil that is wound on top of it . The number of turns is not important , it is the wire length that is important . I hope this answers your question .
zhak
neptune
I never understood how you described.
But watching the video (above topic), I thought the turns on a plastic tube 40 mm, there is their 95 (or so)
And coil of copper pipe enters the Level of 10mm with a winding on a plastic tube 40 mm.
Watch the video carefully, there can see the number of turns
I'm sorry I use a translator
k4zep
Quote from: zhak on August 15, 2011, 06:07:03 AM
hi all
Ben
video (TPP V12 Tutorial Part 6 of 13.avi) time (14.55)
If you count the turns of the plastic tube, then their number would be 95, it is not 10metrov!
Reactor turns 95
Plastic pipe 95 turns
Where is the truth, video, or PDF?
Hi Zhak,
I think there is some confusion here.
Lets start with the small inner copper tube.  I believe in the metric reactor there can be anywhere from between 88 and 95 turns.  TT told me to wind 92 turns on my Inch based center/inner tube.  I think but can not verify yet (First a operating reactor) that for the dimensions given for the metric unit that there is a window with this size wire, etc where it will work from between about 85 to 95 turns but there is an optimum number that gives the best output.  IF and when I or any one else gets a reactor working, then we can begin to tie down the operating parameters of this device.  Folks, I'm in the dark as much as the rest of you and am building on faith as much as knowledge now, in a build by rote mode.  Like the days when we used to build Heathkits or home brew devices.  You built by the numbers and held your breath when you turned it on for the first time!
Outer coil, in the video he shows winding the plastic/outer coil around the reactor with the same number of turns, same winding direction, MINUS 1/2 turn so if you have 95 turns on your inner coil, your outer coil would have 94.5 turns, etc.  This has nothing to do with the 11 meter lengths of wire used in the Cap./dual horizontal coil.
Another observation based on my conversations with TT is that the outer coil is not as critical as the inner coil.  I suspect but have not verified that the outer coil is more of a smoothing choke for the circuit and any reasonable number of turns would work there, again just a feeling.
Now the Capacitor.  Two coils wound one on top of each other using identical lengths, 11 meters of wire. The inner coil will have more turns as it is of lesser diameter.
Remember the video and PDF both in English and that is a secondary language for TT, I feel he has done an excellent job showing how to build, etc.  The questions can be endless. I think we have enough enformation to build it.   I never asked him how long it took him to get the first real pyramid working.  A history of units and the results would be enlightening.
Maybe somebody can answer this question.  WHICH END OF THE INNER COIL IS PLUS, I have to know so I can hook up the fan/exciter right?  Is the bottom junction with the Cap. the positive side and the other end through the outer coil the minus?  I need to look back through this whole thing, and look at the PDF again.
I'm very close to trying my unit.  Still a few loose ends to tie up.  Stable mounting for the reactor, Braces for the front of the pyramid as the weight of the reactor causes the 1/4" gypsum to bow a bit, didn't think about that when designing it!  Must find out polarity of reactor, paint the base of the Pyramid with fast dry paint to keep it from getting wet in grass in the early morning when I will do most of my testing.
Charge the reactor, like I say a few more loose ends.  I am being so methodical here so IF and WHEN I get a working device, I can duplicate it each time I take it out.
The funny thing, walking around in my condo with my dowsing rods, (practice, in search mode looking for water/energy flow from earth), I find a VERY strong indicator right in front of the closet which is the "Worlds Smallest Lab" in the hallway.........I wonder if it will work there.  I am 6 stories up, in a reinforced concrete building, this is NUTS...............we shall see!  So much I don't know.......so much to learn!
Respectfully
Ben K4ZE)
neptune
