Trawoeer Power Pyramid Version 12 - Electrical output from a homemade pyramid
Started by hartiberlin, June 28, 2011, 04:05:30 PM
k4zep
Hi All,
Spent part of yesterday, and most of today, messing, measuring, adding a top suspension point, epoxy here, epoxy there, measuring some more, picture below is of a trial fit.  Bottom of CAP is not cut yet to fit.  Have to put the X lines to be sure centered, also going to put a front to back parallel line to sight the compass for true north also off to the side.
Note the base that is red that the unit sits on.  Never showed that before.  It stabilizes the Pyramid, corners are steel reinforced for more stability and to keep it true, Glued and screwed together.  Also added front stringers to strengthen and keep the pyramid true.  A lot of piddle stuff to finish it right.  Almost there now.  Have to make a "travel box" to keep the reactor vertical when I am transporting it.
I wonder how many out there are actively building/testing a Pyramid?
Respectfully
Ben K4ZEP
GPS25
here are some of my findings for Thoma's Project,Brass Tap Fittings and from the Pet Shop very fine high quality quartz sand.I wonder for those who have found big granule quartz sand if they can use coffe grinder to refine it.Also Brass can be TIG welded using brazing rods.
GPS25
Quote from: DiegoPalma on July 26, 2011, 01:42:34 AM
Capacitor
For the capacitor I used a 20mm x 525mm plastic water PVC pipe with two coils of 11 meters each of the 16 AWG 1.5mm copper cable. I add 10cm to each endings on both coils to connect and synchronize the capacitor.
I cut the endings and mount it in the pyramid to keep the reactor in the exact center of the pyramid as Thomas indicated.
Charging the reactor
The voltage in my country (Peru) is 220v. Here comes the tricky part. I decided to go for the high voltage charging instead of the High Radio Frequency way since my understanding of electronic and RF is limited. I found a high voltage DC transformer made from a fly-back. It makes 20,000 volts (that’s what the seller told me but I couldn’t prove it). I bought a multimeter and there is a warning to do not attempt to measure a circuit if the voltage is grater than 60v DC so I do not know neither the exact amps that are coming out of the transformer, but when I bring the terminals closer than 30mm they make a nice flow of lightning current between (sorry for my English).
I went to a swimming pool service and found two different brands of filter quartz sand. One is Crystaline Silica from Southern Products Silica C.O., INC (first picture) and the second one is a Peruvian brand (more expensive) and is made of ground quartz (second picture). I bought both.
I am going to use the first one since it is more similar in color to what Thomas showed in his video. (The second one is white and irregular in size but I have a 1.5mm frame to filter it if necessary)
That’s all for now. I will wait for your suggestions before going into the next step.
I read that the transformer need to be AC output and between 3 to 7 kilovolts but I have read different approaches and changes of mind in the last days that I am not sure anymore. I hope Thomas can give me the right approach.
Thank you Pascuser for the dowsing articles I would studied them and applied them in my yard. I live in Pisaq, a small town in the Sacred Valley in Cusco (2 hours from Macchu Picchu) at 3,000 meters high (11,000 feet aprox) and  and there is a lot of water underground.
I hope Ben, Matsatbg, Smoky, Pascuser, Duff, Jimboot, Neptune, me and all the rest together can replicate the power pyramid soon with the help of Thomas.
Waiting for your comments...
Diego
have you try this quartz sand from a petshop?I will post you my findings as well.Might be helpful.Regards George
k4zep
Hi All,
Found this little fan at the flea market this morning on our weekly visit for vegetables.
Very small, will run down to 2.8VDC @ 20 ma.  Top end is 5V I think as it came off a video card.
Respectfully
Ben
