Eddy currents and their implications
Started by frankly, July 08, 2011, 04:04:57 AM
z.monkey
Quote from: frankly on July 09, 2011, 01:27:13 AM
Hi there Z monkey. Useful observations you make, regarding loss in a system. However, WHAT MAKES A WATT METER TURN? Eddy currents.
So, what are these "connected to" to provide the lever to turn the disk?
How can this be done with certainty, anytime of the day or night, anywhere in the world?
The coils is oriented in such a way that it provides a linear acceleration on
the disk that is proportional to the magnetic flux.  Non-ferrous metals like
aluminum and copper are resistive to magnetic flux.  If you put the center
of the coil on the edge of the aluminum disk then it can only spin one way.
Well, that is assuming the current is rectified, or the disk is omnidirectional
with a ratchet mechanism.  Yes, those are eddy currents due to the flux
resistive nature of aluminum, and the magnetic flux generated by a coil.
That "god particle" you are talking about I call aether particles, and they
are what is magnetic flux.  The most basic stuff that can be.  Literally
the canvas upon which the universe is painted...
So, although in some instances, eddy currents are wasteful, it is only by convention. When they appear in a coil, they generate energy.
In rare circumstances a coil, by itself, will go overunity.  This is due to external
energy sources.  Usually coils and transformers are exceedingly lossy.  A coil
can be stimulated by external sources to produce current, but it is limited by its
physics.  An example would be an alternator, where spinning magnet induces
current in the coil.  This could also be a number of things such as an ionized
cloud, or a lightning bolt, or fluctuating planetary magnetic fields.  Everything
is relative to the point of observation.  Inductors, by themselves, do not create
current, but when acted upon by external forces can produce substantial current.
Enough current to supply nations, or worlds...
Goodwill to All, for All is One!
ramset
Frankly
Quote:
What Tesla realized was that we can, much like impressing one phase of energy over another, we can impress upon this sphere, a higher order harmonic, and then, all the power of that lower order harmonic, that "pressure of the sphere", is ours to utilize, for the device we connect to it with is tuned ABOVE the ground phase of the planet, to that weaker, higher order harmonic lying on top of the planet's natural frequency....
That sounds nice. {very nice]
Have you done this??
Thanks
Chet
Thanks Grandma
frankly
Quote from: ramset on July 09, 2011, 05:36:18 PM
Frankly
Thanks
Chet
Hi Chet. No, not yet, but I am getting closer to a picture of what is needed to do this in my mind, and that is most of the battle....apart from the building that is!! Of course, with HAARP in the way, there would be no way to do it globaly, however, inside a faraday cage, the proof should be able to be done.
frankly
Quote from: Dave45 on July 09, 2011, 11:49:58 AM
we can build circuits that can build huge amounts of potential-volts but very little amperage and amperage is what we need, its like we are only building half the generator we need a conduit for the amperage.
Watch this vid especially the last part.http://www.youtube.com/watch?v=JcCLIwlbhLc
If this crystal structure were in the core of and inductor we could tap all the energy we need.
Hi Dave. I like the way you are thinking, all that is needed now is to connect the dots. What IS amperage? How is it formed, can it have inertia?
