Eddy currents and their implications
Started by frankly, July 08, 2011, 04:04:57 AM
frankly
Hi guys.
Thanks for joining in, I hope we can all learn from each other. Too long I have been trying to understand this alone, and I keep coming to the same wall. When it comes to applying some math to build devices, I fall over.
Hopefully, many heads will be better than one.
Also, a big thanks to ramset. I was thinking about how to do what you have done, probably easier and far more efficiently than I could have. Thanks.
Also, Forest, Welcome and thanks. Where is everyone from?
I am in Australia, on the South East coast. It is winter here. I work a morning shift, so catch the end of the day in the America's.
I was born and raised here, have never traveled far, and am not  highly educated in the traditional sense. I do, however, seem to have an ability to think "out of the box" a little. This has only come to light for me quite recently, when my wife insisted I be tested for Aspergers Syndrome. Our son is on the spectrum, and so am I.
I did not know that most people did not think in pictures, for many years, and it is only as I have been researching and learning about Tesla, seeing his drawings, following his thoughts and efforts as they evolved, and "seeing" into his mind, that I learned that what I see, is different to what others see.
Forest.
1. Yes. There are. This is what CERN are chasing....the "god particle". A fundamental particle that forms all else. When the background energy of the universe solidifies into matter, it must form a dipole. An area of equal and opposite charge separated by a singularity. The center singularity is the link to the source, so, is the pathway to all other particles as well.
2. These are what Tesla was using.....mas-less magnetic fields. This is Tesla's "Rotating magnetic Field"....a large, mas-less domain within the core of a coil. This is how we achieve energy amplification. By polarising the magnetic components within a core, whatever they are, and oscillating the polarity to increase their natural inertia and AMPLIFY their energy He refered to electric energy as a gas. This he found from his experiments with light. There is an element much smaller than everything else, called Hydrogen, which cannot be excluded from a vacuum. It is very, very close to the inversion layer between the background and this solid universe. It has, as far as we know, three isomer spins. One is neutral, so has no magnetic moment, one is a South pole charge, and the other a North pole.
These particles have mass and are a dipole, (as are all other particles, but we won't go there yet).
3. I am not too sure about EM "waves". I think all is pulse. Expansion, contraction. That is all. With everything spinning. So, catching onto this pulse, at predetermined and equidistant intervals, will appear as a wave to the senses and to machinery designed to do so. This is what Tesla was referring to when he mentions the energy of the planet being able to be utilised to transfer energy.
Much like a wave machine anchored to the bottom of the pond, the stone in the middle does not to be large to transfer energy all over the face of the pond, it just needs to oscillate up and down, right on the surface, in time with the naturally occurring waves, so as not to cancel out the motion, and not to create a disturbance or "standing wave". If this "pond" were a sphere in space, such as our planet, Then all we need to do is find the harmonic nodes, and "pump" the ionosphere.
Presently, if we take an ariel and place it above the ground at 30 feet, we get a potential differance of some 10,000 volts I think. The trouble here is, that we are immersed in this seething mass, and oscillate at the same speed. All matter on earth does. So, we can see this pressure, but cannot touch it unless we ourselves create a differential with voltage ourselves. What Tesla realsied was that we can, much like impressing one phase of energy over another, we can impress upon this sphere, a higher order harmonic, and then, all the power of that lower order harmonic, that "pressure of the sphere", is ours to utilise, for the device we connect to it with is tuned ABOVE the ground phase of the planet, to that weaker, higher order harmonic lying on top of the planet's natural frequency.....
Like I said, simple. It is just that people are not "trained" to think this way any longer.
Mk1
@all
I would not say there is no field around a toroid , but no known field .
I however know there is one , and i did put it to use . Here is the picture ...
The toroid is a little under one inch , the joule thief is a basic one dual single 4 loop coil . The second toroid is made of cardboard with my special winding and connected only to the led , there is no led on the Joule thief .
Dave45
z.monkey
If you have water flowing in the garden hose its a coherent flow, a current.
When the water hits the end of the hose it quickly looses its coherence,
and dissipates as spray, divided down into eddy currents.
The hose is a conductor, to direct the flow...
Compressed air is analogous, in that when it escapes its hose it quickly
looses coherence as the is pressure dissipated in the atmosphere.
Light is also analogous, when light is coherent, like a laser, its is a current.
When the light comes out of the laser it starts to loose its coherence,
affected by eddy currents, caused by friction, and reflection, eventually
looses all its energy as eddy currents as it is dissipated into the environment.
Magnetic, and Electromagnetic currents are also affected in the same way.
When they are in the conductor these forces are coherent.  But, once let out of
the conductor they loose their coherence, and dissipate quickly.  Usually the
inverse square law of energy emissions applies to this phenomena.
I think of eddy currents as the place you don't want your current to go.
Well, unless you want to radiate it...
Goodwill to All, for All is One!
MotovilovDN
Ð' обласÑ,и изучения свободной энергии сущесÑ,вуюÑ, несколько пуÑ,ей для еÑ' понимания.
1. ЧисÑ,о научный пуÑ,ÑŒ. ЭÑ,о более глубокое, чем Ñ,радиционное, знание законов Ñ,,изики.
2. ИнÑ,уиÑ,ивное познание.  Человек делаеÑ, свой прибор Ñ,ак, как ему подсказываеÑ, душа, Ð'ог. То есÑ,ÑŒ Ñ,ак, как ему прияÑ,но и  гармонично видеÑ,ÑŒ свой будущий генераÑ,ор энергии.
3. МеÑ,од образного понимания досÑ,ижений другиÑ... консÑ,рукÑ,оров - Тесла, Ð"рицкевича, СÑ,ивена Марка.  При эÑ,ом можно пыÑ,аÑ,ься на уровне чувсÑ,в поняÑ,ÑŒ карÑ,инки прибора.
4. СисÑ,емный подÑ...од, когда консÑ,рукÑ,ор обладаеÑ, способносÑ,ью комплексного видения всеÑ... Ñ,Ñ€Ñ'Ñ... пуÑ,ей сразу.
