Background discussion of TT`s Pyramid
Started by neptune, July 16, 2011, 10:19:32 AM
NickZ
 Well, those are your thoughts, not mine.  First I must say that the cells are months old, and have been totally dried in the oven overnight even from the day they were made. Second as some people have noticed they can produce a voltage using the same metals, although not to the same degree.  There may be is more to this than a galvanic reaction. These cell are still permanently producing output, are working totally dry and have not died, and can produce as much or voltage as  the pyramid.
Again, what is the voltage and current output of this 3 foot model???
  As I've mentioned before I already have a 6 foot pyramid ready made and only need this reactor and tiny fan etz... to get this replication made.  I'm waiting for the results, which up to now not too convincing.
   As you mentioned you don't need the pyramid... and I personally don't see this reactor as anything else than what I'm working on, now if you can produce 110 volts I might think twice, but, so far I don't see this kind of usable output from any device.
  What is the proof that the pyramid is not a galvanic device???  Iron, and copper,  there you have it.   If what you mean by "to rectify" is the same as what I mean by a conversion process of Aether to usable electrical power,  then they are working by the same principal, which is not galvanic, but something not discovered 100 years ago.   Hutchinson also states his opinion of the crystal cell.
In anycase,  ELECTRIC GOOSE,  I won't waist more of your time as you've already made your mind up.  This is intended for others...
NickZ
  Sorry for the double post, sometimes I press the post button and nothing happens.
Freezer
Quote from: NickZ on July 20, 2011, 09:39:05 PM
Did you watch his videos?  He shows his device powering two motors peaking at 18 watts.  His device is not a battery, and in fact his wire is insulated..
Also I don't see how you can say your batteries have no water, as there is moisture in the air we breathe.  As far as the cells lasting months, I have typical lead acid batteries that last years and put out amps which can be bought for $20...  However I think the Hutchison cell is different, but I haven't seen anyone reproduce it.  He runs a motor on a single cell which I haven't seen anyone do.  I think these cells are worth pursuing, but don't see much relation to what TT has done.
I would take a look TT's videos, they are quite interesting, especially the outdoor one.  If this isn't some elaborate hoax, I think TT has really got something special.
ElectricGoose
Quote from: Freezer on July 20, 2011, 10:24:14 PM
You are absolutely correct Freezer.
Nick...do you want to know the truth when you experiment or not??  You say to me I that I believe what I want or something to that effect and yet this is not true.  I have held beliefs/theories before and yet we must not fall in love with them when the evidence of our EXTENSIVE experiments shows otherwise.
You say that your cells are 'dry'.  I tell you that they are not and this is 100% fact.  I made these concrete cells and placed them in an oven.  IMMEDIATELY after removing from oven when they are definitely 100% dry there is 0 volts reading!!  HOWEVER, stone/concrete/plaster etc is not waterproof entirely.  It is like a big slow porous sponge and even in a really dry climate like where I reside, the ambient moisture (humidity) in air is between 7 - 10%.
What I noticed in my tests, was that 1 hour after the cell had returned to room temp (from hot oven), the cell started building voltage again (lets say 0.1v).  Amps were non existent.  Every hour therafter, the voltage raised a bit more until a few days later when it would peak and this was when the concrete had saturated to the ambient humidity again.
Alternately, you could fast forward the process and just dump your cell in a bucket of water OR even just wet the surface of the visible cement. I encourage you to do this and place the multimeter on it....you will see that the voltage will shoot up.
No magic crystal cell there.
However if you want to ignore the evidence and carry on with time wasting delusion...you do that.
NickZ
  The pyramid is nothing more than a big capacitor utilizing and converting Aether to electricity. As you will see.
   When the cement cells are taken out of an initial 24 hour baking they are not only TOTALLY DRY,  they are burning hot.  Yes, there is water in the air, and still a little trapped inside the cells.  But, as we have come to find out now, that the cells are losing there ability to produce an output over time, due not only from to the water inside drying out, but from oxidation of the electrodes, and the shrinking of the cement from the containers. This we are in the process of studying now, and working towards a practical solution. We are still in the infancy of these power cells.  If they were working on a just a galvanic principal they would discharge like ALL other batteries and need to be recharged, these cells DON'T NEED RECHARGING.  Why?????  If all is known then why is it that you can't you buy a permanent output cell anywhere, for any price.
   I have been watching this pyramid build and information since they were first introduced, but have not seen the outside video that was just made. Please post a link to it as I have not found it yet.
  I am not arguing the galvanic or not theory, just looking for the true  cause and effect, as what is important is the results, the reasons are secondary,  as Thomas also mentions.
  We don't even know what Aether really is, or electricity, or magnetic energy, or what is cold electricity, and other sources of as yet unknown and undiscovered and as yet unmeasurable power sources.
  But, We don't need to be insulted, either,   Electric Goose, if you are so smart why can't you be nice.
