Background discussion of TT`s Pyramid
Started by neptune, July 16, 2011, 10:19:32 AM
neptune
My conmputer is broken and will take some days to fix . I think that when TT says equilateral trriangle he is not being exact .I will return as soon as I can .
fritz
Quote from: NickZ on July 29, 2011, 10:35:56 AM
  So,  a detector is taking in one type of radiation, and converting it to DC current.  What is the point of the conversion?  And how might that be similar to what the pyramid does, or what we are doing here.
   Radiant Energy is  radiated, or is a type radiation, as it is radiated from its source.  Could that be what is being picked up by the pyramid?  Is there any correlation or not?
  Also, if this type of radiation can be converted through a process to produce DC current, even without the use of the pyramid, the pyramid may not be even be needed, if this were true.
I somehow assume that we see a combined process.
The quartz sand may act as piezo/charge pump - but gets stimulated by the moderated/passing by neutrons causing micro-gravitational effects.
So I would assume that the thing produces somewhat pulsed DC.
NickZ
  The pyramid itself may also cause those same effects, that add to the reactor, to produce more energy than what it takes to activate it.  Like a magnifying lens focuses light and makes it strong enough to burn.
tjlitke
Anyone actually tried to replicate TT's work yet?
Mostly I see people trying to explain it away.
NickZ
   To explain it away?  No. To figure it out, Yes.
   Isn't it better to wait and work with a dependable proven and replicable plan in mind?  This thread is for those that are not directly and exclusively building the pyramid model, and are into tossing some ideas around as to its working concept,  while it is further being proven and replicated at the sister thread.
