meyers vic
Started by illuminati, August 14, 2011, 09:50:47 PM
h20power
Quote from: illuminati on August 19, 2011, 02:54:34 AM
I have not tried stainless, it is a ferrous metal, 300 grade is your best bet but use iron i know it works.
what i posted earlier was a little mis-leading, there are 4 coils but 3 spools used in the vic, as explained in meyers vic matrix patent. by reading what i posted u may think 4 seperate spools need to be machined.
h2o stainless is a very bad starting choice, it is unlikley to work as i have explained in this thread. I know i am correct i now understand the basics of this technology, there is no mistake on my part, i have seen it working. time will prove me correct as it has shown the patents have been altered, thats why nobody in 4 years has even one meyer wfc working.
Hi illuminati,
I am not doubting what you have found as I have faith in you. All I did was shed some light on Meyer's choice of wire for there is a reason he used it. The "WHY" is the most important part of all of this for without knowing the "WHY" we have nothing but speculation and endless tail chasing.
So far I have gotten the ER array to work fairly well as I fully understand why it was wired in series now and more. I also understand the compressional style of ER array something no one has seen before. It's all there for us in science just don't listen to the science guys that are paid by the energy sellers for all they want to do is keep things the way they are so they keep getting paid.
The problem I have with the wire is it's size for I would need it in a 0.280 mm wire so things fit correctly in the core I have for it. I have come a long ways since I was booted out of the ionizationx and energetic forms. I can tell you the ER array is not the true source of power being added to the system it is the Gas Processor that is doing this. You can, if you want, take a look at the science I found out about the device here: http://www.hereticalbuilders.com/showthread.php?t=174 But the short version is it works like this; The laser energy works on the atoms from the inside and the ionization energy works on the atoms from the outside and together they do the seemingly impossible and that is to strip far more electrons ever thought possible with such a low energy input. The way it works is suttle and thus far I am the only one that has all the science to prove it works using the known methods of science we all know about.
Just take a look and it will become clear, I hope, anyway your doing great work but remember there is a time limit on all of this with the Dwarf star headed our way to get something up and running to make a difference for the gas supply lines will be cut off if all they say will happen with the Dwarf star's passing. Take care and best of luck to us all in the hard times ahead.
h2opower
illuminati
i think we understand each other on there being hard times ahead, i have sacrificed a attempt at monetary gain to help people. i think we know where this problem stems from (aliens my arse). I get the feeling its to late.
What do u think h2o, should i buy a rv, few cells to power  it and head of for adventure, or maybe build a bunker. decisions  ::)
anyways nice to here from you h2o
happy days
illuminati
forest
I have a question : is that iron wire insulated or not ? I heard about silver plated iron wire being very good in eliminating electron current while which remain is magnetic current.
illuminati
has to be insulated forest or some serious re-design
illuminati
As i have said the primary magnetic field aligns surounding coils electrons so they form magnets that attract to each other (electron clustering)
We can see here how external fields affect electron spin.
When a piece of ferromagnetic material is placed into an external magnetic field, two things happen.
The spins in each domain shift so that the magnetic moments of the electrons become more aligned with the direction of the field.
Domains aligned with the field expand and take over regions previously occupied by domains aligned opposite to the field.
source http://electron9.phys.utk.edu/phys136d/modules/m7/material.htm
this covers permanent magnets but still has relevant information
"Instead, every electron is a tiny magnet due to its inherent magnetism (what we call electron spin).
Furthermore, the alignment of the electron spins makes a hunk of iron (magnetite) into a magnetic lodestone.
All atoms have electrons with electron spin and magnetic fields due to their orbits about the nucleus. But not all material is magnetic like the lodestone (ferromagnetic). If the electron spins of an atom's electrons are aligned oppositely, their magnetic fields cancel. That's what happens with tissue paper, flesh, or other non-ferromagnetic substances.
Each iron atom, on the other hand, has four electrons whose spin magnetism doesn't cancel. They line up. Aligned magnetic fields make matter magnetic.
Iron is a peculiar, remarkable substance. Its aligned-field electrons spontaneously couple and form small long-lasting domains. The spins inside these microscopic domains are almost perfectly aligned. Most domains, though, aren't aligned. In common un-magnetized iron, many domains are randomly oriented"
source http://www.usatoday.com/tech/columnist/aprilholladay/2005-04-01-wonderquest_x.htm
Some materials are unsuitable like copper here it explains why
Since all matter is made up of atoms and all atoms have electrons that are in motion, do all atoms have magnetic fields?
The answer to this question is yes and no. All the electrons do produce a magnetic field as they spin and orbit the nucleus; however, in some atoms, two electrons spinning and orbiting in opposite directions pair up and the net magnetic moment of the atom is zero. Remember that the direction of spin and orbit of the electron determines the direction of the magnetic field. Electron pairing occurs commonly in the atoms of most materials. In the experiment you observed a helium atom showing two electrons spinning and orbiting around the protons and neutrons of the nucleus. The two electrons are paired, meaning that they spin and orbit in opposite directions. Since the magnetic fields produced by the motion of the electrons are in opposite directions, they add up to zero. The overall magnetic field strength of atoms with all paired electrons is zero.
source http://www.ndt-ed.org/EducationResources/HighSchool/Magnetism/electronpairing.htm
