meyers vic
Started by illuminati, August 14, 2011, 09:50:47 PM
illuminati
there is too much confusion and not enough facts to make a sensible conclusion about that video. they have not looked into weather modification technology for example.
2012 looks like a fun year, buy guns and beer lets be prepared
MasterPlaster
@h2o
I am well aware of the situation you pointed in your video. We are going through massive dis-information camaigns but until an external event occurs I would like the masses to have access to free energy but where we are going ultimately, we will not need gold and silver.
@illuminati,
2012 is the target date. we are going through the changes now. Take note of the wars being orchesterated.
If either of you need help, let me know.
illuminati
i think we are all agreed when the masses need food and clean water gold and paper tokens are useless, free energy will be vital as well. what have you got planned for helping?
wfchobby
Quote from: h20power on September 04, 2011, 10:35:30 PM
Here is something for you to watch and learn from: http://www.youtube.com/watch?v=9GMILqaYX3Y&feature=share
Not much time is left to prepare for this.
Take the best of care,
h2opower
To MasterPlaster: http://www.truegreensolutions.net/index.php?p=1_2_Products
Hi H20power
that looks like a nicely built cell set - i notice that the design appears to work like a capacitor in that the only area of water contact is between the 2 tubes - what about the centre of the inner tube - is it left open because i was wondering how you circulated the water from the top to bottom sections of the cell.
With the resonant cavity drawing, diagram attached, where is the earth symbolised connection on the water inlet connected to.? Im unclear of its purpose - is it for setting a electrical polarity on the water entering the cavity.?
the question: On the VIC coil driving the cell - has anyone contemplated what would happen in the circuit if the secondary had a centre tap and that centre tap electrically connects to the water in the cell. ?
What I was curious about was the earthing/grounding of the inlet, and as the vic/chokes/cell are effectively a closed circuit.
Even referring to fig 8-11 of the rotary vic on the alternator setup, the diagram clearly says - water bath electrical ground 0v.
For a ground point for the water, as seen on the inlet of the "resonant cavity", is that applicable to a wfc and if so could a ground, zero point, be utilised by a centre tap on the secondary for as an example for reference, as seen in a simple dual rail psu circuit.??
I can see 2 diagrams that refer to the water being 0v, wfc422da and fig 8-11. Writing by others suggests that on a vic circuit and cell they can get high voltages across the electrodes/plates but little output, so might an area to explore be the potential of the watter as in the 2 meyers diagrams?
is a cell a water bath and resonant cavity.?
BTW - anyone find the kontera.com and infolinks.com underlining of "hotwords in posts and the forum a nuisance? - use Noscript with firefox to prevent the scripts for konterra.com and infolinks.com from being used -  makes the page much cleaner to read
