CRANKYpants
Quote from: shimondoodkin on October 20, 2011, 09:42:46 PM
is there any beneficial overunity in coil only?
DEAR SHIMONDOODKIN,
THAT IS A VERY GOOD QUESTION!  ;)
A GENERATOR COIL EMPLOYS ELECTROMAGNETIC INDUCTION TO CONVERT MAGNETIC FIELD ENERGY TO ELECTRICAL ENERGY. THE MAGNITUDE OF FLUX OFFERED BY THE MAGNETIC FIELD COULD BE CONSIDERED AS THE INPUT TO THE COIL AND THE EMF AS THE OUTPUT. THE ONLY WAY TO INCREASE THE OUTPUT IN A CONVENTIONAL GENERATOR WHILE IT IS RUNNING IS TO INCREASE THE TIME INTERVAL OR RATE OF FLUX CHANGE SPEED UP THE ROTOR OR TO INCREASE THE MAGNETIC FIELD MAGNITUDE IF ELECTROMAGNETS ARE EMPLOYED IN THE ROTOR.
WE ALREADY KNOW THAT THE ReGenX GENERATOR CREATES ITS OWN FLUX RATE OF CHANGE INCREASE BY CAUSING ROTOR ACCELERATION BUT IT ALSO INCREASES ITS OWN MAGNETIC FIELD ENERGY ABOVE THAT SUPPLIED SUPPLIED BY THE MAGNETS ON THE ROTOR.
IF YOU OBSERVE AT 959 IN THIS VIDEO YOU WILL NOTICE COIL #1's EMF INCREASES WHEN COIL #2 IS ENGAGED BECAUSE COIL #2's DISCHARGING FLUX IS ADDING TO THE FLUX AVAILABLE IN COIL #1 AND VICE VERSA. http://www.youtube.com/user/ThaneCHeins?feature=mhee#p/u/13/W_wleUlcMK0
THIS IS ALSO OBSERVABLE IN THIS VIDEO WHEN THE ReGenX COILS ARE ENGAGED: http://www.youtube.com/watch?v=jYi2OyS5cK4
SO THE FLUX MAGNITUDE INSIDE THE CORE IS GREATER ON-LOAD (OUTPUT) THAN NO-LOAD (INPUT).
From Faraday's law of induction: http://en.wikipedia.org/wiki/Electromagnetic_induction
Michael Faraday stated that electromotive force (EMF) produced around a closed path is proportional to the rate of change of the magnetic flux through any surface bounded by that path. In practice, this means that an electric current will be induced in any closed circuit when the magnetic flux through a surface bounded by the conductor changes. This applies whether the field itself changes in strength or the conductor is moved through it.
In mathematical form, Faraday's law states that:
For the case of a coil of wire, composed of N loops with the same area, the equation becomes
EMF = - N (flux change) / rate of time
where
EMF is the electromotive force
ΦB is the magnetic flux.
THANKS FOR THE GOOD QUESTION!  8)
CHEERS
T
Overunityguide
Quote from: gotoluc on October 19, 2011, 10:08:25 AM
Hi Overunityguide,
I also believe the Delayed Lenz effect has to do with the core.
Thanks for sharing your new tests results
You may also want to look at this Tesla Patent which is 4 years later then the one above.
http://www.google.com/patents?id=uwhBAAAAEBAJ&pg=PA1&source=gbs_selected_pages&cad=1#v=onepage&q&f=false
Thanks for sharing
Luc
Quote from: CRANKYpants on October 19, 2011, 07:25:53 PM
YOU ARE ALL ON CRACK...!
IT'S NOT DELAYED LENZ AT ALL IT'S DIVERTED LENZ 8) http://www.youtube.com/watch?v=lu0MDMDChSg  8)
JUST KIDDING A BIT OF BOTH IS REQUIRED ;)
CHEERS
T
Dear Thane, I have to admit that I was to fast by pulling conclusions about that the Delayed Lenz Effect only has to do something with the core material... In fact I think that you are right (again and again, quite annoying!) That it has to be a combination of both... So a properly designed core can help delaying and the Bifilar wound series connected coil can help delaying the counter EMF effect even more. I came to this conclusion yesterday evening when trying only a really thick wire wound coil, which doesn't give me any good delayed effect at all. So based on this experience I had to conclude that the Lenz Delay has to be a combination of both.
With Kind Regards, Overunityguide
Overunityguide
Quote from: DeepCut on October 20, 2011, 03:03:31 PM
Test results, 500g of 0.25mm, bifilar-wound, series-connected, laminated-core coil.
This coil/core combination overspeeds the rotor when shorted.
Rotor with no coil/core present.
Hz : 450
mA : 443
Rotor with coil/core present, open-circuit.
Hz : 450
mA : 438
Rotor with coil/core persent, short-circuit.
Hz : 455
mA 433
Video here :
http://www.youtube.com/watch?v=onvYaT-k7yk
Thanks for reading,
DC.
Hello DeepCut,
Conratulations on your results, do you actually realize what you have accomplished with this experiment?!
(I think you do) But to clarify it a bit more for all other readers of this thread:
What DeepCut has accomplished by now is outstanding. He is showing: 443 mA going to the setup on no load, no coil, no nothing.
And he is showing: 433 mA going to the setup WITH THE BIFILAR COIL in SHORTING mode. And getting extra additional acceleration also!
Until so far I even haven't been able to get this type of results yet. I really hope that your measurements are correct, because if they are and you encounter for all losses, then your setup has the potential to be a self runner! Just like the suggest bike project of Thane himself!
And Furthermore Congrats on Woopy's replication also.
Thanks for sharing your results, and With Kind Regards, Overunityguide
woopy
Hi Thane
Yes you are right, i slowed down the rotor and the threshold  for the pure shortcut of my  bificoil serial connected, is arround 570 rpm.
I mean under this speed the shortcuting produce a braking effect (standard generator behaviour) and the rotor slows down
and above this speed at around 600 rpm the shortcuting produces the acceleration of the rotor.
Between 570 and 600 rpm almost nothing happens. it seems that the rotor is slightly wobling but perhaps it is some balance effect  ??
Totally amazing. Thank's so much for your tenacity on this fantastic work. And especially for sharing it.
So i do suppose that if we can arrange a setup with perhaps an odd and even repartition of coils and magnets (for example 16 magnets on the drum and lets say 7 coils )
in order to reduce the cogging at minima, we could get something  usable...........really interesting. Hmmm!!
Yep a lot of thinking this next days. :P
@ Deepcut
Bravo also for your test. Yes it is really fantastic and somehow disturbing  :o to feel the effect in our's hands.
I can only encourage everybody to try the replication.
Good luck at all
Laurent
DeepCut
Thanks OUG, yes i know what it means :)
Nice one Laurent :)
I am testing again today because, as we all know, results can vary from day-to-day.
Results.
Ten minute device warm-up.
Start, 11:15.
Hz   : 445
mA   : 451
End, 11:25.
Hz   : 460
mA   : 415
Test, No coil/core present.
Hz   : 460
mA   : 415
Test, coil/core present, open-circuit.
Hz   : 434
mA   : 420
Test, coil/core present, short-circuit.
Hz   : 464
mA   : 409
Coil details.
Gauge   : 33 SWG (0.250mm)
Weight   : 500g
Length   : 1,145 metres (approx)
L    : 1.4 Henries without core, 16.5 Henries with core.
R   : 405 OHms
Winding : Bifilar, serial-connected.
Core details.
Type   : Lamination
Grade   : E160/M6/35/Grain oriented, 'I'.
Depth   : 0.35mm
Length   : 40mm
Width   : 10mm
Number of pieces used : 20
Best to all,
Gary.
