totoalas
totoalas lenze (less???) motor http://www.youtube.com/watch?v=SyVa57cVZRE
8)   Shorting the third coil with cap increased the output voltage from 3 to 9 v ac and at the same time increase the speed at a constant voltage output
This voltage can
wings
Quote from: conradelektro on April 09, 2013, 10:44:11 AM
@wings:
Can you deduct anything from Tesla's writings (e.g. from the ones you cited) that helps me to drive the ring magnet as depicted in my Reply #933 (just a few posts above) in a very efficient way?
Greetings, Conrad
Tesla .... too much to read and understand a genius!!!
"magnetic aftereffects" The two main sources of magnetic lag are discussed: lag due to eddy currents, and the so-called
magnetic "after-effect" (Nachwirkung), which is material dependent.
Apart from the contribution to the lag due to eddy currents discussed in
Section 4.1, additional delayed effects have a metallurgical origin (impurities such as C and N in Fe,
dislocations, etc.) and are mainly due to a time-dependent microstructural redistribution associated
with strain induced by magnetostrictive effects. (see http://arxiv.org/pdf/1103.1069.pdf)
..... other interesting material "wiegand wire"?
all is related to d⨕/dt and magnetic retard
some suggestion on general experimental motor construction here
http://www.youtube.com/watch?feature=player_detailpage&v=-ZhwhPCFOA0
wings
Quote from: wings on April 10, 2013, 01:51:51 AM
Adams motor time lag effect
http://www.totallyamped.net/adams/
page 11
Or "why acceleration occurs when a passive generating output coil in an open magnetic system is short circuited or placed under a higher than nominal load".
conradelektro
Quote from: wings on April 10, 2013, 03:47:36 AM
page 11
It is interesting how people rediscover the same effect over and over again and always it gets a new name and a bunch of new "inventors".
Nevertheless, it is an interesting effect. With the right generator coil (some combination of pancake coils) and the right turn rate of the rotor one can may be reach something close to a 100% efficiency with a dynamo.
Greetings, Conrad
wings
Quote from: conradelektro on April 10, 2013, 06:32:21 AM
Greetings, Conrad
Greetings, Conrad
hidden diode ???  ?
