Thanks to ALL for your help!!
Magnetic vortex, eddy heating.
Started by DreamThinkBuild, September 27, 2011, 04:06:45 PM
DreamThinkBuild
Hi All,
Does anyone know what happened to MagnetFlipper? All his videos are taken down.
http://www.youtube.com/user/magnetflipper
This was the last video of what he was working on.
http://www.youtube.com/watch?v=rLlm8UWDNe4
He was also talking about feeding two offset signals into two magnets to see what kind of vortex they setup.
dakanadaka
Quote from: DreamThinkBuild on September 28, 2011, 01:27:38 AM
Hi Chet,
Eddy current heating is the same as induction heaters. Induction heaters, heat metal by high frequency 5khz - 480khz. You can also make magnetic heaters by spinning magnets near copper or aluminum plates it's not very efficient though, about 16% or something. Usually the drive motor gets hotter faster than the plate your trying to heat. :)
A quick one is get a diametric magnet on a Dremel 20krpm and just run it inside a copper pipe. The motor will whine but I've been able to get the end of the pipes temperature up over 200F pretty quick.
The idea behind this test was to see if the magnetic field was actually spinning externally to the magnet. If it wasn't spinning then I shouldn't be able to get heat but as you can see it starts to spin pretty quick and the temp slowly rises. The magnet never physically moves only the water and changing magnetic field. The bubbles that you keep hearing pop is HHO which gets swirled to the center. I put a little cap over the center to capture it and it popped when lit. ELF frequencies are good, between 5-8hz I get a lot of bubble generation.
Spinning magnets at copper plate not 16% !!!! We made it as people on this forum did the math 68% I with my math was wrong apperantly you can see it at http://overunity.com/15882/finally-magnetic-heater-diy-for-free/#.Va0Y95sazCQ , BUT if you want to see it for your self download free document at https://emolio.com/Magnetic-Heater and any kind of suggestion please do so we could test it and inlude and share with all people around the globe :)
