Cheap and Efficient hydrogen oxygen separation HHO cell design
Started by hartiberlin, November 01, 2011, 10:42:16 PM
magpwr
Hi guys,
I have built and posted in youtube ver 1.0 and version 2.0 1watt  HHO generator merely for observing production at that rate visually before increasing power 12volts.
http://www.youtube.com/watch?v=NJw4SSjnejM
Please refer to my other video where i discovered a flaw in Dave Lawton Phase Lock Loop circuit.I have shown in video on how to fix this stability bug for good.
This kit was sold in ebay even the pcb board is sold seperately.
After performing the experiment i then realised there was a scientific discovery made using "super corona dope" to increase HHO bubble production.But only sold in USA.
To date there is only 2 unknown source in youtube which uses super corona dope on the tubes.There was mention to further increase HHO production the resonance on the outer tube needs to be matched with inner tubes.
This is done by making a small cut on outer tubes.If tap on tap the sound should be similar to inner tubes.
By the way there was mention a in site by the scientist by using the super corona dope they saved on conditioning time which ideally takes 3 months.
http://www.youtube.com/watch?v=VPQyxdKidxw
http://www.youtube.com/watch?v=ucA6tCSroiU
I hope this information i have provided will simplify to get you started.
profitis
for mixed h2+o2 chemical seperation is quickest,cheapest,,chromous sulfate solution is numero uno,it removes o2 fast,leaves pure h2.for those who want to seperate mixtures.
Tito L. Oracion
Hi everyone. this might give help to all.
i just found out that using hho is not quite good cause water is accumulating inside the engine and mixing with the oil and off course
the result is overheating and finally your engine will destroy.  :(
so there should have some modification to do about your engine. 8)
cause the accumulated water will go at the bottom in the crankcase and your oil pump will suck that accumulated water to re-use as oil.
hope you are aware about that everyone.  8)
And i think it is not cheap to make engine overall every time. ;D [size=78%] [/size]
Tito L. ORacion  :)
