Ibpointless2 Crystal Cells
b_rads
Quote from: jbignes5 on November 07, 2011, 09:42:26 PM
.5 comes from using copper. Try using graphite. I got 1 volt from graphite and aluminum.
Check around the thrift stores.  Occasionally you can find silver ware (sterling silver) quite cheaply.  Sterling silver is usually 92% silver or better.  Other than gold or pure silver, this is about the best cathode you can find.  Do not use sodium chloride (table salt) with  this and you will be very happy with the results. :)
Brad S
ibpointless2
When I get my paycheck and bills payed off I'm going to be making a even bigger crystal cell. I've figured out a much more simpler way to make the big cells and will also be making a video of the simple way to build these big cells. The short term goal of mine is to make this big cell so that it will be able to charge a super capacitor then I will run my load off of the super capacitor.
I strongly feel that we should not run our load directly off the crystal cells but instead have the cells charge capacitors. I know this seems a bit in the way but you get strange effects when doing this. Even if you have a weak cell you can charge a capacitor and have the capacitor run a more powerful load. The capacitor allows you to convert time into energy. By this I mean a cell takes one minute to charge a capacitor but the cap can run a load for 30 seconds, you convert time to due useful work but in a shorter time. Also capacitor doesn't require us to balance our loads with the cells, the capacitor is a self balancing storage device and when you remove the cell when the cap is full you can power and load you want.
jbignes5
 Damit IB I would have never thought of that process. That is the absolute best way to do this I am guessing.
Also on the subject of silver another great idea. Silver plated carbon or copper even! Think of it like a superfine filter. The silver has it's own particle size and it's own water of crystallization that will form around it! The density change from carbon particle size to silver has it's own unique pattern. This was done on the Power tube that Gray had used.
Gold plating might give the best reaction but finding the crystal structure might be a wee bit hard. On the other hand this matterial we are using Borax might facilitate more charge because the matter of gold is super fine. This would give more resolution per crystal lattice giving an increase in the amplifying effect. This might be the process that the Egyptians used in their Bagdad batteries. I don't think they were using traditional acids to run them. What if they were using sand + salts or crystalline matter and gold plated carbon in the batteries.
I am waiting impatiently to start testing the Bismuth metal in this process. This might open this battery up power wise because it should become a transducer of waste magnetic fields as well. We broadcast tons of magnetic fields into the air all around us.
I still want to know if anyone has exposed one of these batteries to a high voltage electric field like the exciter fields. This way we would be amplifying the made field. John B has shown that the penny type crystal batteries respond slightly to siesmic events and hugely to electrical events like an electrical storm! Someone please fire up an exciter and see the effect of this on the batteries/diodes. This process should have a capacitor that we can run other devices from or even the exciter itself. Even a low field intensity should produce tons of effects and amplify the swing of the signal these diodes tune to. Resonance should tune to the total resistance of the setup and the cap or caps should be selected based on total resistance of the setup via normal RLC calculations.
At some point we are gonna have to start being exact with our formulas and methods. Not just a video of the process it took to make it but a detailed instruction to replicate our findings.
I saw the video of John B showing the method of making a dual gated valve! This is the right method I am thinking to make these dual mode diodes/batteries. I will be starting the process to make one of these DGD. Dual Gated Diode. heh John just happens to make a thin film version. Not so much a battery then. When you have more internal structure or layers it starts to act like a Dual Gated Battery or DGB.
I am wondering if we could do a process of carbon/silver plating/oxide layer/silver plating/oxide layer/silver plating/oxide layer. Would this be possible and would this build in a capacitance so to speak?
nightlife
 My ultimate goal is to use a Joule thief, a bedini curcuit with timer and large coils between the load and cells.
jbignes5
Quote from: nightlife on November 08, 2011, 09:09:14 AM
How about some old Tesla work like this: http://www.overunity.com/index.php?topic=7679.msg304873#new ???
I'm  trusting that our tech will meld with this technology. Since our system will present a potential for this other system to amplify the output of our system and convert it to usable power based on our current system of electronics and electricity. Listen to the power requirements they need. Very little current and moderate voltage at 10 Volts. This should be attainable by our system and will extend it's power conversion to the max for very little cost that our diode/battery will provide.
We got to understand that with the right fulcrum we can move tons of this medium we float in. We have established that there is an energy that we can detect with minute capabilities or resolution. Now it's time to learn just how much this small flow can amplify. This other system that is partly based off of Tesla's rotating field theory is a way to split off a charge through induction without feeding back to the source potential. The more efficient we get this to work the bigger movement we can cause from a small source. Think of this as a non-reflecting inductive diode! In one direction it flows but constricting space through the structure of the crystals. The reflecting bounce back is spread out laterally in a plane 90 degrees from the pyramidal base. So it squirts out in 90 degree disk from the individual crystalline structure defusing by the collisions with other pyramidal crystals. Ok try it this way. Look at the Great Pyramids. the planet has a potential inside of it. We form a mass to draw the potential in a constrictive method to the tip of the pyramid, raising the potential at the tip. This attracts the medium in a downward fashion because of the higher potential. The medium actually has a potential of it's own. This causes the flow downward and outward. When other Pyramids are around the bigger one they generate huge amounts of potential from that flow the bigger one caused. Also this flow can energize water because water is only condensed medium. Hence the walls around the bigger pyramids. When one adds a larger potential still in the pyramid you can stimulate great flows of the medium to become more pressurized or higher density increasing the mediums ability to do what it does.
Our diodes work in the very same way except that we are using huge masses of aligned pyramids to control the separation of charges by 90 degrees, which would separate effectively the charges and reaction of the medium to the charges. As our device gets stronger the other technology gets stronger as well. We have two parts of the technology to harness the medium we float in and we should put them together now while we have time.
