Ibpointless2 Crystal Cells
ibpointless2
I've just had a bad storm move on by here and all my cells seem to have gone up in power. I would say that the increase in power was due to more water being in the air because of the rain but the big blue cell which is sealed with 3 heavy coats of paint has gone up in power too. The only thing I can think of that would cause the increase in power would be a barometric  change. Maybe the change in pressure affected the output of the cells? Moisture in the air would have made more since but the cells that are sealed off still had a increase to. [/size]
[/size]
I guess some test with pressure is now in-order, Maybe put the cell in a tube and blast compressed air on to it could increase the power output! Makes me wonder what they will do in a vacuum? [/size]
jbignes5
I think it is more due to voltage standing.
I havce been watching my Sodium carbonate cell with aluminum and graphite. It has a very curious Ice like crystal growing. This crystal seems to melt from light of a diode. Weird.
NickZ
  If you hold a magnet in your hand, you find that it can move another magnet on the back side of your hand, right through your body.  In a similar way Aether can be absorbed by the two different metals acting like antennas of the cells, right through anything.
  Heat, cold, sunlight, magnetism, lightning, and solar flares, are all different forms originating from the same source, the Aether.
jbignes5
 Almost all correct Nick. The Aether in itself is inert. It is our momentum that drives us through the Aether. Think of it like a huge ocean. We, matter plow through it and it filters into our matter. It is the ultimate solvent. When this solvent is at rest when in comparison to the rest of the Aether it condenses into water. Water is the next phase of it's evolution it shares the same base rules. Finding those base rules is pretty easy. Look for patterns. Mass shows us the base network and it's design. Matter is just a collection or condensed Aether in that mass. When you add charges (also called Heat) it changes phase. Likewise when you take those charges it changes phase as well at certain levels. Phase change can be thought of as density levels of these charges. Most everything has these charges at some basic level. It is after all the background in localized motion. If we are, as a galaxy in motion, then there must be "552 to 630 km per second depending on the relative frame of reference." of Aether moving through or around any matter in our space at any given time.
Also I would like to suggest that time is being recorded in the flow of all matter through the Aether. You could think of it like a hard drive but this one looses the data after awhile. Kinda like a buffer.  Think of it like it's a surface, a medium, as matter collects very minute spaces of this Aether condense as well. They get stronger. They follow Geometric planar electric fields. The planar is surface based and when in sufficient alignment can become very strong. The finer the density of these channels the more power it has. It can suck from a bigger play field with a finer density. It can change it's flow direction and compress it to a higher potential.
I really think your Carbon crystal battery is the answer. But you need to increase the pressure and one way to do that is by the structure of oxides. Once you see how it works you will understand the process more. You need to know about wave guides as well in this example of yours. Start thinking in flows and pressures and you will start to understand what is going on in that device. Learn how to deflect it and compress it and you will have the most powerful device around. Maybe changing the diameter of the crystal wafers would change the tune of the device? Like a woodwind operates???
I was thinking about paints and how we could make paints from the crystal and carbon. Then we could layer this woodwind in many many layers. The finer we get the particles the bigger the bang will be when they vibrate. This is because there would be many more reeds in the piping. I also think that when the oxide is acting like a diode we need to balance the outside electrode every cycle. This way the metal won't break down from excess depletion of charges. We can also tailor the reeds to specific diameters with the thickest crystal layer being directly to the can. The carbon should always be touching the can. You could think about the carbon as the return or ground of the device. Mainly a medium to transfer minute movement into compression for the crystalline layers. When the potential difference is larger for the two types of matter it will slowly leak current. This forms a network of a certain density. When it hits the crystal layer it vibrates the layers causing a lot of generation of piezoelectric potential. Given enough potential we can power devices through induction, that have designed in to it the transformer action of induction. In the meantime the high voltage potential gets transmitted very easily by carbon without appreciable loss.
It could be with the right dopants in the carbon the type and effects of the crystal that forms will change. Synthetic Diamonds have increased electrical capabilities they are finding out. But I'm not sure if it is wise to make a full solid crystalline interior. It could be too much for base metals to contain the growth. but on the other hand being Diamond means no water at all. The crystals we are using have tons of the components of water so dividing Galvanic action is gonna be hard to do.
NickZ
   If you feel that the aluminum/carbon/quartz cell can be the answer, then why don't you build some cells as you've mentioned doing, and see if it really works as planned With the semiconductor, doping, mix, and all.  There is no more convincing idea than a working device.
  I already know what I need to do, and am working towards that direction, in my own way, although I won't know if its the right way to go, until I get there.
  My main point of view is to mention that these cells, are working off of field energies, and not just galvanic reactions, or just advanced galvanics, as Ib likes to call it. I would have discarded them long ago.  It may be a confusing topic, for some, but not for me, although  I may be wrong about that, if I am, I'll be the first to admit it. As I'm not really partial to anything but the truth, as I see it...
   Although some people like Tesla could see or envision an idea before they make it happen for real. I don't have the best forsight, and need to experiment by trial and error, at times. Not the best approach perhaps, but it has worked for me up to now, to a degree. In any case this should all be fun to do, or else we're barking up the wrong tree.
