Ibpointless2 Crystal Cells
0 Members and 1203 Guests are viewing this topic.
triffid
That is exciting that you can use carbon from wood fires.That tells me I should be able to use charcloth.I can see those casimir plates in my mind just extracting all kinds of electricity from the vacuum.According to the three 15 minute lecture series I posted a link to.The energy is comparable to nuclear fusion.It depends on how efficient the crystal cell is.I have made one cell so far that is pulling .14 volts from the vacuum.All of the others are dead or pulling less than .005 volts from the vacuum.I could make more like the one thats pulling a tenth of a volt or more.And put them together in series to make a panel that gets a volt.But I will wait a few days and try to get that morton salt sub which seems to be the weak link in my experiments so far.I most likely will get sodium silicate first then the morton salt sub.I used to live close enough to the arkansas river.But now that I think about it there is a place a mile away from me where I can check out the beach for the missippsi river.So maybe I can find some materials there.Thanks NickZ for the reply.triffid
ibpointless2
@triffid
I look forward to your post on making some cells. I'll be buying some nu-salt  salt substitute to test it out and see if it works or not and i'll trying many other salts as well.
triffid
Hi IB2,I agree you need to check my results.The three  15  minute lectures I posted links to on free energy( from these batteries) said that there has been a lack of standardization on the chemicals used to make these crystal batteries.Hence you have results allover the board
Today you can travel from one state to another in your car knowing that gas from state to state will burn in your car.Because its making is standardized all across the nation.The gas made in conn is the same as in oklahoma for instance.triffid
triffid
I have been going over the pages in this thread very carefully to try to see if I have missed anything.I have magnesium metal strip on order.Today or tomorrow I will get some morton salt sub volts .Roads seem pretty clear now even though the nights are cold.I have been proud of my one cell producing .14 volts until I saw your video getting  where you got .18 volts with just glue and your salt sub.and copper wire and magnesium metal strip.No doubt copper wire and aluminum wire with just glue and my nu salt salt sub would be lower than .18 volts?triffid
triffid
According to NickZ's results I might have been better off using regular table salt.Other things I could think of were(1) didnt use enough epson salts or(2) didnt stir enough. triffid
