Ibpointless2 Crystal Cells
0 Members and 978 Guests are viewing this topic.
PhiChaser
I was thinking about wax the other day too...
I know parrafin is used to full up empty spaces around electronic components sometimes.
IB, thanks for the tip about using the paper towel to wick away the extra water.
Triffid has me thinking that reuse/recycle might be the way to go on these 'bottle cap batteries'...
Will try to visit the dollar store for containers sometime this weekend...
Epsom salt will be next, then mixtures, then tests and more experiments, and making a mess of course! ;)
Cheers!
PC
triffid
At this time the table salt/morton salt sub has pretty much died.I can squeeze it to get 2 or 3/1000ths of a volt.The aspirin cell is holding up at .56 volts down from .6 volts at about 44 hours ago when it was new.I found some junk wire and connected up ten cells from my first panel only to get about .14 volts.A dismal failure to say the least.My cells from the second and the third are doing better but not as well as I had wanted them to.The LED is no longer burning on the second panel but I left it connected in case it comes back on.Our weather is changing so I wanted to see if it comes back on.
I can at least connect my cells in series.Using 6 inch lengths of thin wire from a burned cord from a lamp or something.I wrapped it around the wire and strips of metal and use a piece of black electrical tape to seal it.
triffid
triffid
Things I can do?I guess I could make another tin can lid/mg cell and put aspirin in it.These cells I do not mix but layer.I guess I would put the aspirin on top of the epsom salts?I will stay away from egg carton cardboard for now.I do have a plastic egg carton I can make more cells in.Those cells I can try mixing?triffid
b_rads
Have not checked in for a couple of days and find 2 full pages of posts.  Glad to see the attempt to use recycled materials in your cells.  I can go to the dollar store and purchase 8 AA heavy duty batteries for a dollar.  The use of expensive high quality materials does not really get it for me.  Look around at demolition and remodeling sites for conduit.  This stuff is coated in zinc and that has always produced better than aluminum for me.  The conduit holds up much better than galvanized bolts, nails, washers, etc, for some reason.  I have three water, conduit, copper, cells that have kept a red LED going for over 15 months now.
About recharging batteries:  ni-mh have a horrible efficiency rating, only about 66%.  This is a loss right off the bat.  Ib has explored the use of Caps and I think he is on the right track there.  Do not discount that you can use these cells to recharge each other with the right switching technique.
Keep it simple.  When the materials and reciepe's get too costly and difficult to replicate, nobody wins.
Brad S
ibpointless2
Hi triffid,
What kind of aspirin do you use?
