Ibpointless2 Crystal Cells
0 Members and 1973 Guests are viewing this topic.
triffid
Casimir Force pushes 2 metal plates together.
Finally proven in 2003 to within 5% of values predicted by Casimir back in 1948.
the spacing between plates must be on the order of 2 nm or less. this restricts the larger virtual particles AKA vacumn flucuations from squeezing between the plates. the outside of the plates are still populated by virtual particles both big and small (normal space), This creates a difference in pressure that pulls the plates together.
My theory is that the "abnormal space" between the plates thins out the miniscus of the virtual particle sea by a factor proportional to how close the plates are braced. an electron is free to twist partially out of the normal space by the low density of the miniscus on either side of it. these membranes represent past and future direction and will soon be traveled just like regular space using hydrinos or any molecules that twist then get locked by forming covalent bonds while twisted.
The Casimir effect
In 1948 Hendrik B G Casimir of the Philips Research Laboratories in the Netherlands, proposed an experiment to measure what has become known as the Casimir effect.
Based on the idea that the 'vacuum' of space is actually a seething foam of quantum fluctuations of different frequencies, Casimir proposed that if two electrically conducting, but uncharged parallel plates were mounted a small distance apart in a vacuum, they would tend to be drawn together. An important point is that the plates carry no electrical charge so that any interaction between the plates must come from some other source.
Only toroidinos of a certain size (wave length) can exist between the plates. The formation of toroidinos outside the plates is unrestricted, resulting in a net force that pushes the plates together. This is the Casimir effect.
Assuming that the plates are completely surrounded by quantum fluctuations, we can see from the drawing that the fluctuations between the plates will be restricted to those that will fit between the plates, whereas outside the plates they will be unrestricted. This means that there will be a greater variety and therefore more fluctuations outside the plates than between them, resulting in a net force that will tend to push the plates together.
Casimir predicted the value of this force and in 1996 Steve K Lamoreaux, then at Washington University, measured the force to within an accuracy of five per cent of Casimir's prediction for that configuration of plate separation and geometry.
Over the range measured the force is directly proportional to the area of the plates and inversely proportional to the fourth power of their separation.
As far as I know only a very limited number of experiments have been carried out over a very limited range of plate separations, so it is only possible to conclude that the force is inversely proportional to the fourth power of the plate separation for a very limited range of separations. It may be possible to show that, depending on the shape of the quantum fluctuation, the force may appear to be proportional to the inverse fourth power of the separation at one distance but proportional to some other ratio at a greater or smaller distance.
Whatever the magnitude of the Casimir effect, its very existence indicates that the 19th-century idea of the classical vacuum is fundamentally wrong.
Link to Scientific American article.
DEMONSTRATION OF THE CASIMIR FORCE IN THE 0.6 TO 6 µM RANGE. S. K. Lamoreaux in Physical Review Letters, Vol. 78, No. 1, pages 5--8; January 6, 1997.
Large scale Casimir effects
In the 8 June 1996 issue of New Scientist magazine an article entitled Physics unpicks a sailor's yarn, by Paul Guinnessy, reported on the phenomena noticed in the days of the square rigged sailing ships that, under certain sea conditions, ships lying close together would be mysteriously drawn together until there was a danger of their riggings clashing.
Dutch physicist, Sipko Boersma found that a rolling ship absorbs power from the waves and re-emits it as secondary waves from its hull. If the secondary waves radiated by two ships are out of phase they will cancel, reducing the wave energy between the ships. This is similar to the reduction in radiation energy between atoms or the plates used to measure the Casimir effect. The result is that the ships will be pushed together by the outside wave energy.
Only conditions of practically no wind but with waves on the sea would result in the phenomenon occurring and then the force was so small that the ships could be pulled out of danger by rowing boats.
I had first hand experience of this in 1998, while waiting for our start in the sailing regatta for the New South Wales Hood championships on Sydney Harbour. We had conditions of no wind but a lot of waves caused by everything from power boat and ferry wakes to waves made by arriving and departing float planes. Much to the mirth of the rest of the crew, I made the prediction that, because of the conditions and the Casimir effect, the waiting boats would drift together. Within minutes that's exactly what had happened and we had to continually fend off from boats that literally drifted together into clusters. A firm push was enough to separate the boats but we'd soon drift into another cluster.
So it seems that the Casimir effect applies at levels from sub-nuclear to at least the human scale. I believe that future experiments will show that the Casimir effect operates at all levels from sub-nuclear to cosmological scales.
[/font]
PhiChaser
@ triffid:
The best crystals are made under high heat and pressure.
Pressure is something we can do ourselves with a press like John B. did with Cu, Mg, and the Morton's salt substitue.
Pressure CAUSES heat so maybe if we can press the layers (like you're doing) or wind the wire tighter, or pack the putty tighter, or whatever it is I'm doing... You get the idea.
Now for the heat; Maybe get the mixture of salt sub and epsom salt hot enough to break the H2O loose and press it out? What do you think?
Also, if we were doing this on a larger level a lot of our outgassing would be just hydrogen and oxygen right?
The wax might be worth trying again if the crystal saturation is high enough. By that I mean adding the salts (and powdered aluminum maybe?) into the melted wax until the wax is as removed as I can get it... I'm still not convinced that wax can't work..
Fun stuff! ;)
PC
NickZ
   Sometimes it's hard to know what works until you try it.  But like I said, many of these tests have been done before, and its best to try something that has been shown to work, and take it from there. Or you may find that you are not getting anywhere.
PhiChaser
@ triffid:
Long skinny post! Heh heh...
I liked it though.
Cheers!
PC
triffid
Here is something a little different a repulsive casimir force  silica might keep the plates open longer?   http://nextbigfuture.com/2009/01/repulsive-casimir-force-casimir.html
The scientists replaced one of the two metallic surfaces immersed in a fluid with one made of silica, the force between them switched from attractive to repulsive. So we add a form of silica to our glue cells?[/color][/font][/size][/i]
