Ibpointless2 Crystal Cells
triffid
I went to family dollar today and bought some products that have some good chemicals in them.A styptic pencil($1.50),it contains 56% Aluminum Sulfate and the rest seems to be titanium dioxide.Then"magic shaving powder"($1.25,it was on sale),It contains corn starch,Barium Sulfide,and benzyl benzoate.triffid
My latest cells with pencil leads and magnesium electrodes are producing 1.72 to 1.8 volts.The cells are still wet.Will try connecting them altogether(6 cells) tomorrow.
Murfedit
Aloha i just want to say thank you the years of effort and experimentation have been truly inspirational.
I also have been experimenting for a few years now and came up with the same results as you.
It is not galvanic.  or the galvanic process is slowed which i think it is.
I have had quite alot of success with this mixture    (borax, alum. Sugar.  White glue, copper and magnesium)
Great voltage, and longevity
It seems the rapid deteration of the magnesium can be slowed or halted by the use of sodium substitutions.
I like borax it seems to provide a bond and when mixed with the glue instantly starts to become a polymer so getting it on the anode and cathode quickly while wet is key.  It dries fast.
I am also thinking that it might be thermodynamic reactions of crystals vs insulating polymer giving temperature differences resulting in thermoelectric reactions.
Aloha and thank you again
Murf
triffid
Thank you Murf for your kind words of encouragement.Sometimes I grind to nearly a halt because of some kind of nuts and bolts problem.My flexible wire was not flexible and limber enough to keep from snapping two of my pencil leads.I had good volts but if I cannot connect them?
More on ZPE here http://www.chuckwadeufo.com/ChuckWadeUFO/altenergy5.html[ not quite crystal cells but still drawing power from the vacuum.
triffid
In July 2006 Dr. Tom Bearden and a colleague placed onto the internet a method (calledAdapted NRAM) for a heat amplification process that captures and uses energy from that HUGE energy source. It will take some engineering, but when this process is placed into service it has the potential of STOPPING the use of fuel to produce heat. What if all our coal, gas, oil, biomass, and nuclear power plants could be converted to the Adapted NRAM process?
This is how the heat amplification process works: Use one “part” of the tiny component of ordinary electricity to power an infra-red bulb (something like the heat lamps we are familiar with). The heat from the bulb heats some nano-sized (very, very small) particles. The particles vibrate and draw into themselves energy from that HUGE energy component that we have been wasting, 18 times more energy than the one part of electricity that was used to heat the particles. The particles then radiate out 18 times as much energy in the form of heat as was used to turn on the infra-red bulb. This excess energy drawn from the Huge energy flow can now take the place of the coal, gas, oil, biomass, or nuclear type fuel that would have been used to fuel the power plant.
A big blownup diagram of NRAM: http://www.chuckwadeufo.com/ChuckWadeUFO/altenergy5_files/Adapted%20NRAM%202009.pdf
triffid
So powdered tourmaline crystals(or something like it) would be our source of photons from ZPE.Hence number three in the NRAM diagram in the posted link above would start applying itself to our crystal cells.3 thru 11.triffid
