Rosemary Ainslie
2/... Which begs the question, what actually has changed as a result of that fire if the atoms themselves remain inviolate? And the answer is evident in the wood that will have lost its bound condition. Conversely, the previously unbound condition of the iron filings would have become bound. And other than a few escaping gas atoms and molecules, all those atoms involved in and associated with that fire, may not only be entirely accounted for, but they would and do remain substantially unchanged. The actual atoms comprising all parts of that experiment and its experimental apparatus remain exactly as they were prior to their exposure to those flames. It is only their bound condition that would have been altered.
           In as much as the atoms are known to remain unchanged as a result of the fire, then the material source of fire may have little, if anything, to do with an interaction between those atoms. The fire itself may have a material cause that is extraneous to the atomic material from its source. If so, and as it results in an unbinding in that transfer of its heat from the material of the wood to a binding of the material of the filings then, what is actually being transferred in that exchange of energy, may be that binding material. By extension, therefore, this binding material may also be the material property of that flame. Which suggests that three-dimensional bound structures, be they liquid, solid, or molecular, may be bound by something that is extraneous to the atom.
           It is this ‘something’, this binding material, which is here proposed to be the hidden material construction that not only is responsible for binding matter into its identifiable structures, but it may also be the foundational construction behind all the forces. A magnetic field model identifies this binding field as a single discrete, one-dimensional closed string of orbiting magnetic dipoles structured as a Line of Force (Fig 5). And this precise one-dimensional field is identified as the fundamental structure upon which all the Lines of Force are developed because it is, in fact, all that is needed. It is the essential and profoundly elementary construction with the required potential to interact with the three valence conditions of atomic charge. For ease of reference this orbiting string of dipoles will be called a ‘binding field’
           The assumption is made that these binding fields are magnetic and that they are constrained to only interact with other magnetic fields. They obey an immutable imperative to move to a condition of charge balance. And this actual atomic binding could, therefore, be managed by an orbit of these strings, which can be seen, in the mind’s eye, as a small cog, (the binding field), interacting with the boundary of a bigger cog, (the atom’s outer energy levels). Both fields are proposed to comprise Lines of Force. And, being closed strings, then the charge of both the atom’s energy levels and the binding fields are perfectly balanced and thereby rendered undetectable. The difference in these two fields is proposed to be only that of size. The atomic energy levels are proposed to be more complex, two-dimensional magnetic Lines of Force, having length and breadth.
Rosemary Ainslie
3/...
           But the question remains. Why are these fields undetectable? And the proposed answer to this is that they are indeed detectable. They are seen every time we light a fire. In effect, flame itself is proposed to be the hot material property of magnetic dipoles that have moved out of their field condition as a coherent Line of Force into a chaotic imbalanced mass of conflicting raw charge. As there is also a proposed and immutable imperative for these dipoles to structure themselves into an orderly field then they needs must search out material in their immediate environment to reassemble into those discrete and structured fields. In effect, they are looking for something to ‘bind’. And having found the required disassociated atoms or molecules they can then transfer through space to reassemble into those discrete packages of their coherent field condition, by binding disassociated atomic material.
           A variation of this ‘binding’ and ‘unbinding’ is proposed to be the motor that drives the electromotive force. But to explain this first requires a close analysis of the closed Line of Force. One half of each of those closed strings will oppose the other half. And if they orbit, then one half of every orbit will still oppose the other half. The orbit itself is a composite of a potential bi-directional path through space. And whether the orbit is clockwise or a counter-clockwise, then whole of the field would be neutral. In effect, each Line of Force, whether or not it is orbiting, would be balanced by its own innate structure, which would render the binding field neutral. Therefore, in summary, the field would essentially comprise the sum of two opposite potential spins and therefore, two opposite charges. Each part of each field would be charged, determined by the alignment and/or the justification of those magnetic dipoles. Yet the field itself would be neutral.
           Current flow, on the other hand, is proposed to be the dynamic condition of voltage that comprises open strings. And its movement through the circuit is led by a single justification or direction or charge. This is here further proposed to be either the negative or positive half of each dipole leading the string that also leads the current. See figures 7, 9 & 10. And unlike the proposed binding fields, current is known to be mono directional therefore it only has one charge. The binding fields would be located in that circuit material that is presenting a path for the flow of current. Therefore when current flows through the circuit material it would repel that half of each of those binding fields in its path that present a ‘like’ charge. And this force of repulsion is then proposed to break the symmetry of that orbit of these binding fields.
           Broken Lines of Force would also be open Lines of Force. And unlike their closed condition, open Lines of force have an identifiable charge. In terms of the Laws of Charge, like charges repel. So one half of that field would, of necessity, be repelled by the current charge. And having been repelled it would also then restructure as an open field outside that circuit material, and would be measured as voltage. This is proposed to be the source of the voltage that results from EMF.
Rosemary Ainslie
4/...
           The remaining half of those Lines of Force, are now no longer able to attach or to orbit. These fields remain within the structure of the circuit material. But they have lost that interaction with the atom’s valence energy levels, which thereby become unbound. It is proposed that these broken Lines of Force then tumble out of their coherent field condition and, like the sparks in the flame, they get bigger and hotter as more and more of these fields move into this shared state of chaos. These broken strings then lose their orbital momentum. This unbinding, or unbundling of the field string structure, represents a chaotic condition where the level of binding of the circuit material becomes compromised. The early evidence of this is that the circuit material itself expands to accommodate the increased volume of these, now big, hot and slow, magnetic dipoles. So it is that the magnetic dipoles themselves are here proposed to be the source of heat, which is exploited in electrical applications.
           The magnetic field model referenced hereunder, has proposed that these Lines of Force comprise magnetic dipoles. It further proposes that all particles are composites of these tachyons. And as the model is able to resolve the mass/size ratios of the proton to the electron, it may thereby constitute some proof of postulate. The objective of this appendix is to summarize these concepts relating to the electromotive force. It is stressed, however, that there is no material departure of these concepts to mainstream physics other than in the proposal of a magnetic dipole being the fundamental construct or ‘building block’ both of the magnetic field and of matter. The significant and further departure from mainstream is that these dipoles are here identified as the material structure of ‘flame’. This, in turn, begs the ratio that in the field condition the particles are as fast and cold and invisible as, out of a field condition they are as hot and slow and visible. And their quantized value of spin and charge is required to be intimately variable depending on the atoms that they bind.
           Also of significance is that these fields may be the source of the ‘dark force’ that has been proved by astrophysicists. And on a broader scale it may also be the source of the strings that are required by our string theorists. But, as it is based on Faraday’s Lines of Force, then there are no significant departures from mainstream thinking. The hope is that it will resolve some outstanding questions related to those many paradoxes that are identified by mainstream.
hartiberlin
Rosemary,
don´t work on your thesis paper,
it is a wasted time cause the measurements are in error.
Just work on measuring the battery status before and after the experiment.
This is the only way to see, if your circuit really puts out more energy than it consumes...
Regards, Stefan.
Groundloop
@All,
Today I did build the attached circuit to see:
1. If the circuit did oscillate with a negative voltage bias.
2. If the lead acid battery did charge up when the circuits runs.
The circuit oscillates very nicely when I connect the 9 volt battery,
and stop to oscillate when I disconnect the 9 volt battery.
The current usage from the 9 volt battery is approx. 0,9mA.
If the main input/output 12 volt 60 ampere lead acid battery
will charge up when the circuit is running, remains to see,
because I need to run the circuit for some time first.
GL.
