New forum software update done
Started by hartiberlin, November 14, 2011, 04:18:44 PM
Groundloop
Stefan,
Still does not work when I press (more attachments).
I can't upgrade to Firefox 8, it will not run stable on my
operating system. So, I guess I have to accept that
problem and just upload one attachment at the time.
GL.
wattsup
Quote from: Groundloop on November 15, 2011, 08:32:49 PM
Stefan,
problem and just upload one attachment at the time. GL.
Not only that. No buttons like bold, quote, etc.
@stefan just open the firefox 8.0 like mine just updated and it does not work. Works OK with IE.
One member at SMF Forum said the pages are not "validated".
If you go here, http://validator.w3.org/
then open a post page and copy the url to the validator page and you will get the errors.
Anyways, I opened a post page and looked at the source file. In the image below is part of the source file where the attachment is too happen and where you can see the "break return"
 in the file is in error as
. There should be no forward slash and this is probably the root cause of the errors. IE does not see these as problems but it is not real html and Firefox does not like it.
Since I can only post one attachment, I will attach a second image as next post showing now the buttons section of the source file. Again here the red forward slashes should not be there.
wattsup
Hahaha, as I post this I get the session time out with the image I wanted to post  now in the attached section. so the attach other file is now available again. So if you post only one attachment, then go back to modify the post fast enough, you can add a second image then go back again to modify and add a third image. Wow lot's of work but this is a work around the problem but not the solution.
kEhYo77
I have problems with attachments as well in chrome it says that it cannot be validated... ???
WilbyInebriated
attachment test for: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.9.2.12) Gecko/20101026 Firefox/3.6.12
attempting .jpg .png .swf
noscript users take note: allowing javascript for www.overunity.com was required to allow multiple attachments... and for the formatting options like bold, smileys, etc.
WilbyInebriated
Quote from: wattsup on November 15, 2011, 09:52:17 PM
all tags MUST be closed to validate as XHTML 1.0
this applies to
 is correct and will validate. <img> tags would require this as well. eg: <img src='somefile.jpg' border='0' />
obviously XML and HTML are different entities, but the idea is to have your html be well-formed xml. HTML5 is getting us close. see stackoverflow for a more detailed discussion: http://stackoverflow.com/questions/1946426/html-5-is-it-br-br-or-br
