SMOT
Started by KSW, April 11, 2005, 08:45:18 AM
0 Members and 61 Guests are viewing this topic.
infringer
you want a magnetic motor I will give you a hint of an idea or epiphany that I had think of a stirling engine or the concept of its power generation then apply that to a magnetic motor if done right bingo magnetic motor untested but in my mind it works while a little dissimalar from stirling in concept it is the same but it would need an inital start and maybe a means to disconnect at a certain speed and let spin perfectly timed think on the order of merry go round if you give it a little tap at the right time in keeps gaining speed untill your hand gets sore, your buddy pukes, or your kid wets his pants :P
It should work give it thought the more I read the more ideas I get... I may elaborate on the idea a bit further if people are interested in testing but will do so in a separate post cause I dont wanna hijack the whole thread.
And no I'm not trying to be cryptic I simply am sickly and need to conserve some brain power for reading or possibly posting on other subjects gotta love them colds!
REGISTER AND BECOME A MEMBER RIGHT NOW!!!!!
........::::::::: http://www.energyinfringer.com  :::::::::........
"""""""everything is energy and energy is everything""""""
-infringer-
Low-Q
A motor works because of the magnetic aligments, whitch also alter in a revolution. To alter magnetism mechanicly repuires the same energy as it take to rotate. So the result of a magnetic setup is allways trivial at most.
