FLUX RESONATOR
Started by tishatang, June 21, 2006, 02:59:52 AM
pinestone
When viewing a magnet that is perpendicular to the lens surface and a point-source light, the photons follow the lowest potential of the magnetic field. This type of experiment not only shows the 'Bloch wall' that you refer to, but also the bi-directional 'flow' of the field. Very much like Howard Johnson's computer plots do.
This image shows it well: http://www.nanomagnetics.us/anothermoebius3.jpg
The physics community will not accept this because it conflicts with their standard model, but our experiments show otherwise.
pinestone
Quote from: pinestone on June 16, 2008, 06:17:47 PM
In addition, here's an interesting movie made by one of my collaborators using a special Flux Resonator lens:
http://www.scivee.tv/node/5988
enjoy !
wings
Have you done experiment adding a coil with pulsating current on one end of the magnet in order to move the block wall this can be very useful to understand many OU devices?
Marzio
pinestone
Yes, our early experiments were performed using electromagnets. We've found it takes a lot of current to equal the Teslas obtained with small neodymium magnets. For simple tests, the neo's work very well-
They don't get hot and they are 'ON' all the time.
If I was trying to build some sort of OU device, I certainly wouldn't use electromagnets. You're screwed right from the get-go, as any type of wire (other than super-cooled) has a resistance that will reduce the efficiency of the device. You couldn't even achieve unity, so there's no chance of over-unity, no matter what the arrangement (or claims).
