Water as fuel problems
Started by rickhunter7, June 21, 2006, 10:47:12 AM
rickhunter7
Hello.
I am highly interested in using electrolysis to generate fuel to run a car engine. I have read testimonials that state that it is possible to generate the neccesary amount of gas from the water on demand, enough to run an engine, the only problem I see is the necesity of protecting the engine cilinders, pistons, valves, and exhaust from corrosion, to do this they (the testimonials) say that it is neccesary to apply a "ceramic coating".
So, what is this ceramic coating anyway? who does it? is it expensive? can you do it yourself?
I would appreciate any highlights on the matter.
hartiberlin
Have a look at
"byron energy joecell"
or
"ringorgone"
at
http://video.google.com
But their principle is very utopic...
just using implosion via orgone energy...
no real fuel for the pistons...
pese
the best tips to eleminate corrision problems with ceramic coating
come since years from CELLA
http://www.hasslberger.com/tecno/hydrogen.html
because also proban an butan gas have an lot of water ,if  burned in heaters , also motors , the people that use butan gas for autocars , start
the first 10 minutes to drive with gasoline , swap to gas (if hydrogen - do it)
an drive als the the last 10 minutes wit gasoline , so this way the motor
will we come"dry", from any water inside the motor.
i know this system since 40 years , otherwise most motors , as mercerdes,
wil not work so long time
There are some inventions related to ic-engines and the used
fuel-mix:
water+copper
water+aluminate
water+iron
water+carbon/graphite
=water+minerals  =mineral-oil
Hreha,Scott,Cornish,Kelly et cetera ... .
This indicates that there is a fuel alternative,so there
is only more the search for the "ideal" engine surface coating !
S
  dL
rickhunter7
One question. Have any of you ever succesfully run a car on water/hidrogen/whatever?
