Ghazanfar Ali Generator - Utlilizing trapped energy
Started by Ghazanfar_Ali, February 04, 2012, 03:14:30 AM
e2matrix
Good to see Ghazanfar_Ali is back.  It made no sense from any view point I could imagine that he was just scamming us.  I hope he realizes the difficulty in getting this circuit into the hands of people who really need it if it is not open sourced.   The planet will suffer and it's people will suffer unless it is shared.  He of course can still make good money in many ways from the information as discussed in many threads here.   If it is not shared I'll bet some sharp people here will be able to figure out what is relevant from Zilano's posts here:  http://www.energeticforum.com/renewable-energy/4864-donald-smith-devices-too-good-true-2.html
Note also that Slovenia and some others have condensed all her posts into a document that can be found somewhere in that thread.
energia9
Fe device...
maybe..
Or?
even using 2x 9v bateries its possible to light a 40 watt incandescent lightbulb, for short period of time but still.
see
http://laserhacker.com/SuperJouleRinger2.html
go to 10:40 in the video
question-
how long did the bulb lit from the same battery?
what type of battery was used?
Ghazanfar_Ali
OK Guys ! Here is the secret
Make an oscillator say 15KHz freq. It is driven by a 12 V DC source capable of giving 2A current. The waveform produced by osc must be a sinusoidal. Step up the signal using a fly back transformer. Rectify the high voltage output using a series of diodes. store the charge in a Cap bank. Use a spark gap to quench the charge. the spark gap will be parallel to the cap and the pri of an isolation transformer. This produces a very very large voltage spike again and again at much larger freq say 35KHz. Step it down to use more current and low voltage. (Zilano's and Don Smith's secondary windings). and give HF driven load of 2KW. use the further step down to get rectified 12 V from the output and feed it back to input through a diode and a 4700uF electrolytic cap. Remove the battery source and see the magic.
u require fine tuning of tfr 1 and tfr 2.
All is the game of resonance.
Good Luck
Ghazanfar_Ali
Ghazanfar_Ali
My country is the biggest sufferer of electricity short fall these days. Where out of 24 hours people have to sweat in summers for avg 18 hours. And I am really working hard on finalizing this product so that everyone should be able to cut off from and independent of the main grid of Power Mafia.
