LENR Roundup
Started by fritz, February 13, 2012, 03:22:12 PM
profitis
Wattsup:'Once you have a device that can go OU, you still have the rest of eternity to figure out any transmutation, real or not right now does not matter.'
True.the negentropy of the hysteresisloop itself is a marvel there is no need for transmutation.infact,the hysteresisloop can be made to do actual work for very long times if kept under the 'profitis point' ie.under the point of stress where nuclear disintergration begins to happen.when nuclear disintergration into the lower energy states actually happens it changes the surface properties of the material components and will bring about both physical and nuclear wear and tear.It was rossi who used a totally stable enriched nickel isotope in one of his earlier designs to avoid this wear and tear and keep the loop going for aslong as possible at maximum gains.nickel 62 is totaly stable and will not undergo further collapse ( other elements in contact with it may do so if they're not in their lowest states within the loop)
profitis
Wattsup:'What I am afraid of is this effect will be sidetracked with the discussions of transmutations (TM)'
Very difficult to predict what transmutations will happen anyways unless via trial and error.every element will have its own 'profitis point' in a particular hysteresis loop.the same element's 'profitis point' may even differ from loop to loop.
sparks
     I'm just thinking that alot of cold-fusion products are because a pseudo neutron or mini atom type deal is presented to a nucleus or forms in a nucleus.   This causes instabilities inside the nucleus which can promote the pseudo neutron to a real neutron.  The energy needed coming from the strong force rearranging the nucleus.
http://www.journal-of-nuclear-physics.com/?p=488
http://www.scientificethics.org/NeutronSynthesisNCA-I.pdf
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
profitis
From ecatworld:
'Ian Walker
Hi all
One obvious thing people seem to be missing, is that LENR is a Low Energy Nuclear Reaction. Neutrons produced are not going to be the fast moving high energy Neutrons of Hot Fusion or Fission.
Any Neutrons produced in LENR are far more likely to be absorbed in the matter they are being released in and produce isotopic changes. Or indeed decay before exiting the reactor, any Beta so produced will absorbed in the mass of the fuel itself and produce anomalous heat. It certainly would not have enough energy to escape the reactor.
MFMP and others have reported Gamma bursts at the start of some of reactions, that then disappears. It almost seems analogous to a car backfiring before running steadily.
Kind Regards walker'
This is because of the negentropy of the loop.the negentropy demands to raise the loops energy and absorbs all or most of atomic ejection particle/wave energies before they are even formed.this results in endothermic collapse of atomic matter for already stable elements(high 'profitis points'). elements which are already unstable(low 'profitis points') may shoot higher-energy particles out of the loop and go exothermic
profitis
"When a nuclear event occurs within the
province of the bose condinsate... a
condinsate that has accumulated the
required combined excitation energy
shared among the members of its aggregate
members, the weak force no longer
functions as a separate force. In this
condition, the excitation produced
by the nuclear reaction is instantaneously
relaxed into a stable
configuration."
Here's the clasper or pincher-effect that I predicted long ago in my language.the "profitis points"
