how my electric wheel is used to multiply electricity
Started by one_christian_warrior, February 17, 2012, 12:38:50 AM
Brian Coats
You did not provide enough information on the AC Motor. A Normal AC motor will not generate a current without electricity applied. Perhaps this one had magnets in it? I am confused on how the AC was generated. Could you please specify a bit on that particular part of the system you have brought?
pinchopeyepupa
Hey man, if this is legit, then this device will change the world and it is of big importance to all people, especially those who need electricity just to survive. If all this is true and you are giving it out for free, then do a step by step tutorial in youtube for people that dont even know about basic electricity. Hope you have success.
Tito L. Oracion
@ ocw
want this system possible?, then  PULSE IT!  >:(
crazycut06
Quote from: Tito L. Oracion on July 22, 2012, 01:08:11 AM
@ ocw
Just how UFOPOLITICS did to his motors?
Good day!
Cc
SkyWatcher123
Hi folks, Hi onechristianwarrior, thanks for sharing, are you still out there.
I wonder If this needs a heavy mass like the Tilly setup that was based on a setup from a man I think by the name of Wilson, on a farm that used a very large diameter wooden table with nails on edge to hold the very long belt pulley.
This man also said, that it ran itself and a load, until the nails worked themselves loose.
Then we have Lawrence Tseung's large pulsed wheel that leads out excess energy.
Then we have the Chas Campbell heavy mass wheel system with pulley ratios.
I feel the list of people claiming excess energy from devices like this, that there is something to it.
If onechristianwarrior's device does not need a heavy mass flywheel, then I could see using a bicycle wheel, either somehow attach directly to wheel or attach a motor to the pedal axle system and use the gearing, then we can use the tire to contact the shaft of a generator/motor/etc., this would give a large step up ratio, like 1 to 50, plus the sprocket gearing ratio.
Though it might be said, that his weight and the electric scooters mass could be deemed a flywheel mass, so maybe a flywheel mass is needed.
Anyone contemplating giving this a try.
peace love light
tyson ;)
