Electricity Multiplier machine
Started by one_christian_warrior, February 26, 2012, 09:04:45 PM
here is another drawing of this mechanism
which is better at showing how to use multiple generators
derricka
OCW,   It's very simple. What you are proposing WILL NOT WORK.  The fact that you have drawn 3 generators in your diagram suggests you don't understand how much mechanical force it takes to turn a loaded generator.  Making  that amount of mechanical power, will cause the electric motor to consume more electrical power than any generator (or combination) can provide.
And posting it in at least three different threads makes it three times less likely to work.
But that's ok because 3 x 0 is still zero.
that_prophet
Quote from: TinselKoala on April 27, 2012, 09:16:07 PM
AND HOW DO YOU EXPLAIN AWAY THIS PLAIN LOGIC
Let me describe a simple project:
You have a 100cm circumference pulley attached to a DC motor,
You connect a belt to this large pulley + 10 small 1cm circumference pulleys,
These mini-pulleys have AC motors/generators attached, (with no load at first)
Now you rotate the large pulley by hand,
This gives you a return of 10 X 100 = 1000 units of AC power
Now,,, try and tell me that this 1000 units of AC electricity,
Does not have enough voltage (electrical pressure)
To rotate your DC motor one time, (all voltage + only a spark of current)
Your "logic" is faulty because it is based on incorrect assumptions and your own fixed ideas, which are wrong. Garbage in, garbage out, no matter how good the "logic" may be.
It is useless for you to continue spamming SIX THREADS with your unworkable device (which, by the way, is a member of a class of devices called "Q-Mo-Gens" by Sterling Allan at PESN).
This scheme _does not work_ and if you would just do a few actual experiments of your own, you might come to realize it yourself. In the meantime, just what is your justification for posting the _same things_ in six different threads? Do you think you'll do anything besides annoy people with your spamming of the forum?
