Electricity Multiplier machine
Started by one_christian_warrior, February 26, 2012, 09:04:45 PM
truesearch
@that_prophet:It very much appears that you aren't willing to consider some obvious comparisons that I presented on one of your earlier "threads". So let's try this again. In keeping with your preferred method of copy&paste I will do that same with the following:
I'm sorry but it appears like your "vision" is not very well connected with the created world that we exist in. Please try to read the following and give it some rational thought:
Let's take for this example one of King Solomon's chariot wheels (maybe at 5' for this example):
1. If you where able to put 2 of these chariot wheels together on a single axle it shouldn't be that terribly difficult to push them around on the flat plans of Jezreel. This is very comparable to your electric motor turning your wheel WITHOUT any AC generators attached (are you with me?). Nothing gained at this point.
2. Now, if you take this same 2-chariot-wheels-on-1-axle device and begin to push to up the road in the hill country of Gilead you will IMMEDIATELY notice that it is more difficult (and you will likely break out in a sweat) because you are exerting WORK to counter the GRAVITY. This is pretty much a dead-on comparison to attaching 1 AC generators to your 5 ft wheel driven by your electric motor because the motor must turn the 5' wheel which, in turn, is dragging along the generator which RESIST turning because it is PUSHING the electrical current being generated. Sort of like you pushing those chariot wheels up-hill.
3. Finally, if you take that chariot-wheel device and drag it up Mt. Horeb you are going to stand out as a hero of old (especially if go like the driving of Jehu). Regardless, this is symbolic of you attaching 2 AC generators and expecting to get any electricity generated from them. That POWER-OUTPUT is the mechanical input being converted to ELECTRICAL. No more, no less. The GRAVITY that you would work against to go up-hill with your chariot-wheels is very much of a comparable drag as the AC generators.
sincerely,
truesearch
that_prophet
Quote from: TinselKoala on May 07, 2015, 04:59:29 PM
Your "logic" is faulty because it is based on incorrect assumptions and your own fixed ideas, which are wrong. Garbage in, garbage out, no matter how good the "logic" may be.
It is useless for you to continue spamming SIX THREADS with your unworkable device (which, by the way, is a member of a class of devices called "Q-Mo-Gens" by Sterling Allan at PESN).
This scheme _does not work_ and if you would just do a few actual experiments of your own, you might come to realize it yourself. In the meantime, just what is your justification for posting the _same things_ in six different threads? Do you think you'll do anything besides annoy people with your spamming of the forum?
PLEASE, LET ME EXPLAIN
God has shared this SUPER SIMPLE TECHNOLOGY with an end time Joseph,
To show the world FREE ENERGY
Just before the TRIBULATION begins,,, 2020 Vision, (2019.1) is the Door-deadline
To help furnish the END TIME REVIVAL
http://free-energy.yolasite.com/
This logical conclusion is simplicity at it's best
You are merely using geometric change in solid objects, (pulleys)
To drastically multiply your # of rotations,
This is significant within the electronics field,
Because rotations can be converted into AC electricity,
So,,,, you are not only multiplying rotations,
But you are multiplying you AC electricity,
This can be done in any voltage,
And the multiplication factor is seemingly without limit,
WHY ARE WE USING MIDDLE EAST OIL,
TO GENERATE OUR ELECTRICIY,,, ???
When we could simply use pulleys to multiply it for free,,,,,,,,,,,,,,,,,,,,,,
http://beliefstoliveby.yolasite.com/
SATAN + HIS EVIL SPIRITS HIDE THIS SIMPLE REALITY
THIS IS NOT ONLY PROOF OF CONFLICT BETWEEN GOOD + EVIL,
BUT THANKFULLY THIS CAN ALSO BE SCENE AS PROOF OF GOD,,,,,,,,,,,,,,,,,
http://decimationofthisevolutionfairytale.yolasite.com/
MarkE
that_prophet
Quote from: Goat on February 26, 2012, 11:57:41 PM
Hi one_christian_warrior
Thank you for opening your thread on this subject.
I looked at your schematic and was wondering if you had actually tried this or is this a thought experiment?
I'm not sure if it would work quite as you showed but maybe I missed something, I'm not an expert in OU BTW  :P
Paul
Neither am I an expert Paul,
but if you have all your motors without any load,
they are the easiest to rotate.
This gives you 1000 sparks,
which when put through full wave bridge rectifiers,
should be able to combine to give you one large spark,
surely enough to have a DC motor turn over once.
ayeaye
Quote from: that_prophet on May 10, 2015, 05:16:45 AM
This makes that task very difficult. Even TinselKoala cannot replicate.
Don't use the word God without reason, well, said my grandfather.
