Hydro Gravity Roller
Started by vineet_kiran, March 10, 2012, 03:30:29 AM
vineet_kiran
Quote from: AlanA on March 13, 2012, 12:02:26 PM
@ Veneet_kiran
and now? have you discarded you idea?
@AlanA
I have not discarded the idea.      I  mean to say  that  it works  only as a roller  moving on a track and not as a wheel mounted on center axis.
Vineet.K.
JEJEHO
Hi veneeth,
This also not possible becasue the centre of gravity of the two weights up and down will be allways inside the cylinder.  With the weight of water the centre of gravity of the system will be allways inside the cylinder not above the cylinder. So the cylinder will not roll becasue of the centre of gravity is inside the cylinder.
Nixon
vineet_kiran
Quote from: JEJEHO on March 14, 2012, 07:14:29 AM
Hi veneeth,
Nixon
@JEJEHO,
I have verified that experiment.   It rolls.   The experiment is dependent on rotating moment which depends on difference between top and bottom arms.   When top arm is longer than bottom arm with equal weights,   the top arm has to fall down  as per lever rules.    I didnot understand the center of gravity theory.   The moments of force act  on the edge of the cylinder on which the arms are leaning and not at the center of gravity.
Vineet.K.
JEJEHO
Hi Vineeth,
If it works continue your research.
Wish you a great success in your research.
Best wishes
Nixon
AlanA
@ Vineeth,
Is it possible to post some photos from your researches?
Greetings
AlAn
