quentron.com
Started by Philip Hardcastle, April 04, 2012, 05:00:30 AM
0 Members and 35 Guests are viewing this topic.
lumen
Quote from: sarkeizen on January 28, 2013, 12:20:17 AM
And in one case WillThisEnd is always, always, always, always wrong.  Must be hard on the ego to see something no engineer or even all engineers or even all engineers past and future can ever fix.Utterly wrong.  WillThisEndOnSelf is accepting exactly the output that WillThisEnd sends it.  However WillThisEnd just happens to always be wrong in this case.
(Huckleberry hound is for Bruce_TPU)
It's not wrong until it gives it's result!
The change in status is based on the result of WillThisEnd(program);
WillThisEnd(program); must return the correct result in order for WillThisEndOnSelf to return an incorrect response.
Still, clever but WOT.
sarkeizen
Quote from: lumen on January 28, 2013, 12:23:31 AM
You are making a reifying error.
All that's required for my position to be correct is for any WillThisEnd(program,data) to fail in one circumstance.
If WillThisEnd is presumed perfect - it fails on WillThisEndOnSelf and I'm right.
If WillThisEnd is presumed imperfect - then it fails all on it's own and I'm right.
Since perfect and not perfect cover every possible circumstance.  I am right.
Believe it or not in the past 70 years mathematicians have thought about this stuff.  Even if engineers couldn't.
So you are you ready to concede?
(Fred and Barney for Bruce_TPU)
lumen
Quote from: sarkeizen on January 28, 2013, 12:54:32 AM
The fact is that "WillThisEnd(program,data)" did not fail. It did return the correct result.
Just because  "WillThisEndOnSelf " failed sometime after, has nothing to do with "WillThisEnd(program,data)"
If not (WillThisEnd(program,data)); is the same thing.
The very last error that occured was the failure of "WillThisEndOnSelf" not "WillThisEnd(program,data)".
The proof is that to correct the problem, you would not correct "WillThisEnd(program,data)" because this subfunction is working correctly and always returns the correct result.
Even after the failure of "WillThisEndOnSelf" in the lowest brackets, the subfunction "WillThisEnd(program,data)" in the next level of "WillThisEndOnSelf" correctly detects the failure and returns the correct result. In fact the incorrect result are never returned, the function "WillThisEndOnSelf"  simply hangs up.
One can easily write a truth table of results to find the error was not caused by "WillThisEnd(program,data)" but later in the function "WillThisEndOnSelf".
So just because you wrote a program that fails to return the results of  "WillThisEnd(program,data)", is not proof that "WillThisEnd(program,data)" failed to return the correct results.
It's a failed attempt to show that the function "WillThisEnd(program,data)" returns the incorrect result.
Bruce_TPU
Fred and Barney, Starkey?  How quint.
sarkeizen
Quote from: lumen on January 28, 2013, 11:05:09 AM
Nope.   Under the *assumption* it produces the correct result it fails to do so.  Different thing.
QuoteJust because  "WillThisEndOnSelf " failed sometime after, has nothing to do with "WillThisEnd(program,data)"
Squirm, squirm, squirm. You are equivocating...typical.  What stage of Kübler-Ross are you in now?
Failure requires a condition.  There were no conditions placed on the operation of WillThisEndOnSelf.   Therefore it can not fail.  On the other hand WillThisEnd() has conditions on it's operation and it failed to meet them.   You said yourself that we can feed complete random garbage into WillThisFail and it will still predict the action of the supplied program.  You were wrong.
If you place conditions on WillThisEndOnSelf in order for WillThisFail to predict it's outcome then of course you fail yet again.  Since WillThisFail no longer works on any program.
Sorry, put your (written like a pre-schooler) snippet in a function otherwise it's irrelevant.
Not in any useful sense of the term "failure".  The only thing that could fail was WillThisEnd and it did.
Again, you should concede this point.
Bruce_TPU - Glad to see I'm keeping your interest.  After all I'm smarter than the average bear...and apparently Engineer.  In that spirit I've attached a picture of Yogi for you.
