Electronically generate rotating magnetic fields
Started by Eighthman, May 01, 2012, 07:46:45 PM
CompuTutor
I remember something with a fancy name like "inclinometer magnetometer",
it was a glass ball, with a smaller glass ball inside, with fluid between them.
The center ball is free to move, as it is suspended in the fluid,
and had a rod magnet in it to act like a compass to earths field.
It would not only show magnetic north for us northern hemisphere folk,
and also the penetration angle at the location it was used at too.
It was in a plastic gimbal frame with gradient markings to interpret it.
Anyone know where these can be had for cheap for those building TPU's ?
If the damping factor isn't to high, it could help adjust interactive frequency sets.
Easy enough to make one from a pair of those inexpensive
two-piece gumball machine toy containers, and a magnet.
A very thin kitchen oil should allow a fairly fast spin too...
Bruce_TPU
Quote from: sidneo on May 01, 2012, 10:16:13 PM
Hi bruce,
do you think i should use strait wires in a cylinder  or a toroid to achieve this .
i need a solid state rotating field on my circuit .
link : [size=78%]http://magpowersystem.free.fr/Page_5_fichiers/Circuit%20simple.gif[/size]
Hi Sidneo,
I think you should think along these lines....  ;)
http://www.overunity.com/12144/eblv-genmotor-design-by-bruce/msg321090/#msg321090
Cheers,
Bruce
Eighthman
Holy Cow! Read this exhaustive analysis of the TPU derived from hours of examining photos.
http://www.slideshare.net/niculaegeorge/a-detail-study-of-the-steven-mark-tpu-10721103
Very impressive
pauldude000
Something for you to consider. First, you will notice that the original wiring diagram I had posted forever and ten years ago included the setup they demonstrate. What is wrong with the picture is that these coils will not make a rotating field......
The field, instead of rotating, swings back and forth, as they are exciting it with AC according to their waveform. AC reinforces back emf.
It would only appear to rotate. (Though this appearance would be in two dimensions as soon as the field itself reverses due to back emf.)
True rotation would be awesome, but inherently extremely difficult. It involves a ton of math, and relatively precise wire lengths (Including lead in and connective wires have to be included in the calculations.)
It has to be high frequency (Due to the speed of transmission of electricity in a wire. Higher frequency, shorter wire in the coil.) Low frequencies can cause rotation as easily as high frequencies, but the coil length can be astronomical, and the speed of rotation will be inherently comparatively slow.
I guess the ultimate question is which kind of rotation are you after?
Linear in relation to the circumference? (Coils aimed inline of circumference with magnetic lines following circumference. Very hard, limited use. One Tesla patent that I know of.)
Diagonal to the circumference? (Coils aimed at point of rotation, magnetic lines of force cutting across the circumference. . Relatively easy, examine any large size AC motor with both rotor and stater windings. or in a different configuration a small ac induction motor.)
Have some fun, make a stack of six and do both, with each layer counter rotating in relation to the one above, with serious juice..... Just let me know when, so I can find shelter.  ;D
Finding truth can be compared to panning for gold. It generally entails sifting a huge amount of material for each nugget found. Then checking each nugget found for valuable metal or fool's gold.
enron-r-crooks
If anyone is still looking for a circuit, a doc is available from
http://www.stealthskater.com/Documents/TIME/RotatingFields.doc
and a ton of info at
http://www.stealthskater.com/PX.htm
You can use this to drive the coils in this page.
http://www.edn.com/article/457397-Electronically_generate_rotating_magnetic_fields.php
I heard SM was into audio engineering  :-X
