Fernando`s Force multiplier
Started by neptune, May 03, 2012, 03:09:35 PM
Merg
Fernando's Force Multiplier System = Veljko Milkovic's Patent YU 545 MP?
There were some remarks in discussions that this appeared to be related to the basics behind Veljko Milkovic's two stage mechanical pump.
It seems it is similar to the Veljko Milkovic's patent filled in 2002 and granted in 2003:
Hammer with an electric motor drive and rotating eccentric masses - YU 545 MP - MP-122/02
Abstract
A hammer driven by an electromotor with eccentric rotating masses, consists of the base (2) to which are attached: anvil (4), stand (20) to which is attached electromotor (17), stand (3) for the hammer with shaft (7) around which the rod (6) keeps rocking, and stand (1) of the chain with shaft (14) around which two-armed lever (9) is rocking. Above anvil (4) is mounted the head of the hammer (5) attached to the handle (6) while the opposite end of handle (6) is connected to lever (9) through the use of connecting plates (8. On both sides of lever (9) are mounted two pairs of eccentric masses (10) with shafts (11). One mass on each side has grooves around its circumference. Shaft (14) has bearing (13) and it serves to attach a wheel (15) which drives chain (16). Wheel (15) is firmly attached to shaft (18) of electromotor (17) by a forked coupling (19). Wheel (15) and eccentric masses (10) are connected by chain (16), where eccentric masses (10) are turned in such a way that the center of their masses are on the opposite sides of the lever (9) i.e. they are shifted for 180 degrees. On the two-armed lever (9) are also mounted idlers (12) which serve to control chain (16).
Full patent document with the patent drawings (in Serbian)
http://www.veljkomilkovic.com/Images/Patenti/Veljko_Milkovic's_patent_Hammer_with_an_electro_motor_drive_and_rotating_eccentric_masses.pdf
i_ron
Quote from: caccr2000 on September 17, 2012, 02:11:44 PM
hagan una pasada por este foro sobre este inventor
http://foro.redjedievolution.com/viewtopic.php?f=43&t=3397
Thank you caccr, however the patent seems to lose something in translation
http://aplicaciones.indecopi.gob.pe/por ... lowing = 2010
Registry Data   Patent
Title:   FORCE MULTIPLIER SYSTEM
Date of Award:   30/05/2012   Maturity Date:   05/08/2030
Rating:   F03G 7/08
N ° Title:   6454   Publication Date:   16/07/2011
Priorities:
Summary:   Comprising two parallel disks joined by a shaft, IN THE MIDDLE OF A BREAK THESE DISCS ARE PRESENTING A EXTRINCIDAD, in prolonging SHAFTS HAVE PLACED TWO STATES BY SHOOTING AXIAL SUPPORT, in turn is connected by BREAK COVER LIKE A PIECE INTERIOR symmetrical within convenient
Ron
Edit: sorry the full link didn't highlight, please cut and paste
i_ron
Hi all,
Here is a picture showing input and output on the same shaft. note the considerable weight
on the "flag", center mounted low, and the channel iron link extensions painted blue.
Note both motor and generator belt driven
Ron
Edit: Now what is surely puzzling to me is for the 'flag' --- if the big disc is about 8 inches dia of 1/2 inch plate and the small discs are about 5 inches of 3/4 inch plate the total weight is say 13 pounds. !3 pounds on a 18mm rod would last about 5 minutes at 1600 RPM before being flung across the room???
gotoluc
Quote from: i_ron on September 17, 2012, 09:29:49 PM
Hi Ron,
I would agree that in normal circumstances the weight would fly off that size of shaft. However, maybe once all hits Resonance the destructive force transfers to the flywheels somehow?
Thanks for sharing
Luc
