Radiant Electriciy Generated with Spark Gaps and Induction Coils - Theory
Started by bajac, May 07, 2012, 07:14:01 PM
onepower
nix85
QuoteSeems you are incapable of understanding English. My post above literally says "Gotta correct myself" followed by a diagram showing IV distribution in the secondary and highlighted "current in the base is high and diminishes along the height of the coil".
My bad, I was rushing through the current posts and missed your correction.
I have found using analogies and visualizations can give us better insight.
For example we could imagine the charge density along the length of a tesla coil like a spring. The high potential at the top makes each turn of the spring repel the next turn more giving less turns per inch. Like wise near the bottom of the tesla coil the spring has less potential, less repulsion thus more turns per inch. So we can visualize how charge density in the tesla coil relates to the density of the turns on our spring.
We can also visualize the electrical pressure/flow of the system and understand that the point of highest potential is the point where the charges have nowhere to go. If the charges could move the potential would be lower but they cannot which is the reason why the highest potential/charge density equates to the lowest current flow. Likewise near the bottom of a grounded tesla coil or one attached to a large conducting object the charges do have a freedom of movement. So it seems reasonable that if the charges could move they would show us the region of the greatest current.
This is why I prefer visualizations over equations or math which seldom show us anything new. For example, if our charge density/spring was elastic we can imagine oscillations within oscillations. We could see longitudinal compression along the spring length, vertical deformation like a sine wave or a singular impulse like a soliton wave. The next step would be to imagine ways and means of making what we visualized a reality. This may be why some say "a picture is worth a thousand words"... or equations.
In fact Nikola Tesla claimed he visualized and perfected every concept/invention in his mind first. I believe this is why he made so many new discoveries while many others didn't. Obviously having already seen something working in every detail in our mind is a lot easier to build than just guessing.
AC
nix85
Quote from: onepower on September 21, 2021, 04:30:12 PM
nix85
No problem and sure.
QuoteFor example we could imagine the charge density along the length of a tesla coil like a spring. The high potential at the top makes each turn of the spring repel the next turn more giving less turns per inch. Like wise near the bottom of the tesla coil the spring has less potential, less repulsion thus more turns per inch. So we can visualize how charge density in the tesla coil relates to the density of the turns on our spring.
Your spring analogy is ok but capacitor analogy is more suited here since open ended wire literally is a capacitor parasitically coupled to ground. As charge accumulates toward the top of the coil current proportionally decreases.
"the reason it takes higher voltage to pack more electrons on the plate of a capacitor, obviously, higher the electron density higher the repulsion to further electron inflow to the plate."
We can make these analogies and they are not mere comparisons, they are literal analogies, what is a spring or a swing but an LC tank, they are one and the same, just different forms of potential and kinetic energy. Same formula applies for Q-factor, for standing wave ratio etc.
QuoteThis is why I prefer visualizations over equations or math which seldom show us anything new. For example, if our charge density/spring was elastic we can imagine oscillations within oscillations. We could see longitudinal compression along the spring length, vertical deformation like a sine wave or a singular impulse like a soliton wave. The next step would be to imagine ways and means of making what we visualized a reality. This may be why some say "a picture is worth a thousand words"... or equations.
Visualizations are important, most of us are visual learners. Actual dynamics of what is happening are infinitely complex, we might also bring in the proximity effects, displacement current and whatnot, subtle interactions and interferences are beyond computation.
QuoteIn fact Nikola Tesla claimed he visualized and perfected every concept/invention in his mind first. I believe this is why he made so many new discoveries while many others didn't. Obviously having already seen something working in every detail in our mind is a lot easier to build than just guessing.
AC
I prefer this approach too, 95% visualization, mind simulation, 5% materialization. But what has Tesla coil have to do with Tesla? He only patented it, he did not invent it.
In fact, he did not invent the the rotating magnetic field nor the induction motor he is most known for. Rotating magnetic field and crude motor based on it was invented by Walter Bailey (UK) in 1879 and more advanced one by Galileo Ferraris (IT) in 1885.
As for Tesla Coil
"Tesla was not the first to invent this circuit.[21][15] Henry Rowland built a spark-excited resonant transformer circuit (above) in 1889[2] and Elihu Thomson had experimented with similar circuits in 1890, including one which could produce 64 inch (1.6 m) sparks,[9][22][23] [1] and other sources confirm Tesla was not the first.[14][24][15] However he was the first to see practical applications for it and patent it."
https://handwiki.org/wiki/Engineering:History_of_the_Tesla_coil
Above is not mentioned Jacques-Arsène d'Arsonval, possibly the first inventor of 'Tesla Coil', photo below.
Don't get me wrong, Tesla did some incredible work, especially in the area he is least known for covered in Gerry Vassilatos books and elsewhere.
It would be more correct to ask what has the resonant transformer popularly known as Tesla coil have to do with REAL Tesla coil which is a higher dimensional resonator and takes into account more than just LC resonance.
onepower
Nix85
QuoteYour spring analogy is ok but capacitor analogy is more suited here since open ended wire literally is a capacitor parasitically coupled to ground. As charge accumulates toward the top of the coil current proportionally decreases.
I believe the capacitor parasitically coupled to ground theory was disproven which my experiments also agreed with. It was found that in reality the majority of charge doesn't couple to ground but water vapor in the air. It was also found that the majority of charge is not stored on the material surface but water vapor absorbed by said surface. The phenomena was first thought to be a "charge matrix" structure but later was proven to act similar to double layer capacitance. Which also relates to why some FE devices and many of my own worked one day and not the next, it was relative humidity. This is where conventional theory tends to break down because they purposely exclude most external variables and pretend things operate in a closed system.
Quote"the reason it takes higher voltage to pack more electrons on the plate of a capacitor, obviously, higher the electron density higher the repulsion to further electron inflow to the plate."
I agree which is why I like my spring analogy because we would see the spring turn spacing changing exponentially from top to bottom and not in a linear fashion. Which begs the question what we would see using a capacitor analogy when the field force remains invisible. On a similar note, did you know the lines of force concept is invalid?. It's actually similar to my spring analogy and the lines are produced by magnetic and electric field induction. Not EM induction but either magnetic induction or electric induction. The actual effect is due to the fact parallel particle/objects having like polarities repel and series particle/objects having unlike polarities attract naturally forming lines, lol. Can you see how one simple flaw in our perception can lead to a whole field of science based on a fallacy?.
QuoteWe can make these analogies and they are not mere comparisons, they are literal analogies, what is a spring or a swing but an LC tank, they are one and the same, just different forms of potential and kinetic energy. Same formula applies for Q-factor, for standing wave ratio etc.
To my knowledge all of the greatest minds in FE believed in mechanical analogies because they followed the Aether/dark matter-energy theories. In fact I know of no credible FE inventor who demonstrated a working FE device who actually believed in General Relativity and this warping space-time nonsense. They all believed space including the space matter occupies is full of smaller particles and energy. Thus all forces and the translation of force relate to the motion of something and we can use mechanical analogies.
I mean this nonsensical spooky action at a distance thing is getting old isn't it?. It reminds me of a cat chasing it's tail giving the appearance of progress but never getting anywhere, lol. Think about that, decades have past and nobody is any closer to understanding what the Primary Fields (Electric, Magnetic, Gravic) are in reality. Not only does nobody have a clue what the Primary Fields are but they have literally no place to start. Why do you suppose that is?, thus the only conclusion I can come to is the same as Einstein... GR is a pipe dream.
AC
nix85
Quote from: onepower on September 22, 2021, 02:00:56 AM
Nix85
Ground is a relative term, as Don Smith said, it can mean earth ground or air ground. When we talk FE and ether, we are not talking electrons but smaller particles which can become electrons when joined.
More here http://www.villesresearch.com/ether.html#Vitality%20globules
QuoteI agree which is why I like my spring analogy because we would see the spring turn spacing changing exponentially from top to bottom and not in a linear fashion. Which begs the question what we would see using a capacitor analogy when the field force remains invisible. On a similar note, did you know the lines of force concept is invalid?. It's actually similar to my spring analogy and the lines are produced by magnetic and electric field induction. Not EM induction but either magnetic induction or electric induction. The actual effect is due to the fact parallel particle/objects having like polarities repel and series particle/objects having unlike polarities attract naturally forming lines, lol. Can you see how one simple flaw in our perception can lead to a whole field of science based on a fallacy?
Lines of force concept is invalid? I will have to absolutely disagree. You took a wrong path my friend, you have put the particle before the field.
The very essence of time-space IS matrix of electric (male) and magnetic (female) lines of force crossing at 90°, spiraling around each other. Here is some info from George Van Tassel.
The G line of TIME or Poynting Vector separating the A (electric) and B (magnetic) lines of Primary Light is an insulator between the two which spiral around it and continue their eternal dance by partial induction, male being what is known as speed of light and female 16,000 miles/s faster and proportionally less dense.. to understand these mechanics read the Council of 7 lights by Tassel. There you will learn that what we feel as gravity are magnetic (negative) lines of Primary Light streaming into the Earth attracted by the Earth's electric (positive) core. You will also learn how crossing of A and B lines of same frequency produces nodes where their substances meet (mating!) generates so called particles and much more.
Lines of force are the essence of creation of time-space. In contactee case from planet Iarga we find that 'space' is an illusion created by 6 AXIS OF TIME (which oscillates but does not move). Each matter antimatter universe like a diode or sprocket wheel picks oscillations in one direction only, their timelines diverging. Relativity of speed of time between nearby time axis produces the angle of 60°, a harmonic ratio 1:2.
This is the key of it all, the essence of relativity, creation of time-space from nothing. More here https://galactic.no/rune/iarapdx1.html
QuoteTo my knowledge all of the greatest minds in FE believed in mechanical analogies because they followed the Aether/dark matter-energy theories. In fact I know of no credible FE inventor who demonstrated a working FE device who actually believed in General Relativity and this warping space-time nonsense. They all believed space including the space matter occupies is full of smaller particles and energy. Thus all forces and the translation of force relate to the motion of something and we can use mechanical analogies.
AC
Space is filled with ether indeed, somewhat less densely than around the planets, but ether does not dismiss the bending of time-space and relativity of time. Relativity IS correct. It is just his dismissal of ether in a sense of actual substance filling all space that is indeed incorrect.
"Spooky action at a distance", teleportation, instant communication over lightyears of distance is easily explained by higher planes of existence, two point may seem wide apart on our level but on higher plane they are right next to each other, speed of light, density of matter and rate of time flow all increasing by x49 on each plane above. We also know time actually stops on some astral levels so there are bands, but general rule is everything getting faster and denser x49 on each plane above. Ironically, denser means feeling less dense, higher energy level.
Again, relativity is not a pipe dream, time dilation is correct, warping of time-space is correct, speed of light for herzian waves is somewhat off but almost correct, cosmological constant is correct..much from Einstain is correct except for dismissal of actual subtle matter filling all space.
Here i will quote a whole chapter from the book Solar System by Arthur Powell, a theosophist. It describes a creation of our solar system, not only on this plane but on 7 planes of the lowest cosmic plane.
If you don't wanna read it all, here it is in short..
All levels are made of same most subtle "matter" (neutral units of consciousness) condensed into ever larger basic structures on each of 7 great planes and inumerable subplanes always following the ratio of 49 (encoded all over Bible), that is, 49 neutral bubbles of the highest of all planes condense into smallest particle of the next lower plane and so on. This is the reason density of matter, speed of light and rate of time flow all increase by x49 as we go toward higher planes. These neutral bubbles of consciousness have no apparent vibration nor inner content, they are but voids in the Ether (Koilon in Greek - hollow). Only in cruder forms these bubbles create particles, 'atoms' which have polarity, male projecting particles from higher plane into the lower and female returning them back completing the circle, their spin is opposite. It is interesting to note, as revealed in Spiritist literature, these most subtle bubbles on each plane are eternal, planets and suns form and dissolve back into this materia prima only to be reused eternally.
CHAPTER VI
THE BUILDING OF THE SOLAR SYSTEM
HAVING now studied, in broad outline, the general plan of the,
"field" of evolution in our solar system, it will be useful to go
over the ground again, filling in certain further details, and
considering also the way in which the system is originally
constructed out of primordial matter.
This time we shall commence with the large unit - the system
as a whole - and steadily work our way down to the smaller units
- the globes.
Before our solar system came into existence there existed
the ultimate root-matter, the substance out of which will be
fashioned every type of matter of which we have any knowledge.
This root-matter is what scientists call the ether of space, and
what has been described in Occult Chemistry under the name of
koilon (Greek Koilos, hollow).
This must not, of course, be confused with the etheric
matter which composes the finer part of our physical world.
To every physical sense, the space occupied by koilon
appears empty: yet in reality this ether is far denser than
anything of which we can conceive. Professor Osborne Reynolds,
the originator of the celebrated theory, which agrees with occult
investigation, defines its density as being 10,000 times greater
than that of water, and its mean pressure as 750,000 tons to the
square inch.
This substance is perceptible only to highly developed
clairvoyant power. We must assume a time - though we have no
direct knowledge on the point - when this substance filled all
space. We must also suppose that some great Being - almost
infinitely higher than the Logos of a solar system - changed this
condition of rest by pouring out His spirit or force into a
certain section of this matter, a section the size of a whole
universe.
The effect of the introduction of this force is as that of
the blowing of a mighty breath, forming within the ether, or
koilon, an incalculable number of tiny spherical bubbles. These
bubbles in koilon are the ultimate atoms out of which everything
that we call matter is manufactured.
They are the atomic matter of the lowest cosmic plane. Out
of them the Logos of our solar system will presently form the
seven planes of our system, those seven planes, taken together,
forming the lowest cosmic plane.
It is probable that the force by which the bubbles were
originally formed is what H. P. Blavatsky called fohat, which she
spoke of as "digging holes in space," thus reminding one of the
recent dictum of a French scientist that "there is no matter;
there are nothing but holes in the æther."
The bubbles are not like a soap-bubble, which is a film of
water with an outer and an inner surface, enclosing air within
it. They are like bubbles in sodawater, which have only one
surface, where the air meets the water.
As has just been said, to the highest sight available the
bubbles appear to be perfectly empty, so that it is not known
whether any motion is going on inside them or not. Neither is it
known whether they are rotating on their axes or not.
They seem to have no proper motion of their own, but they
can be moved as a whole from without, singly or en masse, by an
exertion of the will. No two bubbles ever under any circumstances
touch each other.
When the Solar Logos - the great Being of Whom our solar
system is some representation, corresponding possibly to an
incarnation, in the case of a human being - chose to manifest
Himself, when He came forth out of eternity into time, and wished
to form this system, He found ready to His hand this material,
this infinite mass of tiny bubbles.
He commenced by defining an area, the limit of His field of
activity, the limit, perhaps, of His own aura, a vast sphere,
whose circumference is far larger than the orbit of the outermost
of His future planets.
Stupendous as this area would be, the distance between solar
systems is yet out of all proportion greater than the systems
themselves. Nevertheless, it is probable that the Logoi of the
systems are actually in touch with one another, on the higher
planes.
Within the limit of the sphere thus marked out He sets up a
motion which sweeps together all the bubbles into a vast central
mass, thus condensing or compressing the bubble-matter, which was
originally scattered throughout the whole of the prodigious
space, into a smaller region.
At a certain stage in that condensation, or compression - a
stage when the radius of His globe still extended far beyond the
orbit of the outermost planet of the system, as it exists to-day
- He sets up within it a whirling motion, accompanied by intense
electrical action, thus making a colossal vortex in many dimensions,
the material of the nebula that is to be.
The compression of the whirling mass is continued through
what to us would be untold ages: in fact, the vortex made by the
Logos in the first place is still in action. In the course of
that process of compression, He, acting through His Third Aspect,
sends out seven impulses or "breaths."
The first impulse sets up all through the sphere a vast
number of tiny vortices, each of which draws into itself 49
bubbles, and arranges them in a certain shape. These little
groupings of bubbles, so formed, are the atoms of the second
plane or world - the anupâdaka or monadic plane.
The whole of the bubbles are not used in this way, but
sufficient are left, in the disassociated state, to act as atoms
of the first or âdi world.
In due time there comes a second impulse, which seizes upon
nearly all the 49-bubble atoms - leaving sufficient to provide
atoms for the anupâdaka world draws them back into itself,
disintegrates them into their component bubbles, and then,
throwing them out again, sets up among them vortices, each of
which holds within itself 49² or 2,401 bubbles. These are the
atoms of the third world, the plane of âtmâ.
Again after a time comes a third impulse, which in the same
way seizes upon nearly all the 2,401-bubble atoms - again leaving
sufficient to form the atoms of the âtmic world - draws them back
into itself, disintegrates them, and throws them out once more as
the atoms of the fourth world, that of buddhi, each atom now
containing 49³ or 117,649 bubbles.
The process is repeated until the sixth impulse has built
the atoms of the seventh or lowest world , the physical plane,
its atoms containing 49ˇ6, or approximately 14,000 million of the
original bubbles. These atoms are not, of course, the atoms of
which chemists speak, but the ultimate atoms out of which all the
chemical atoms are made.
The numbers of bubbles contained in the atoms of our seven
planes are given in the following table:
Plane ³
Âdî . . . . . . . . . . . . . .1
Anupâdaka . . . . . . . . 49
Âtmâ . . . . . . . . . . . . 401
Buddhi . . . . . . . . . . . 117,649
Manas (mental) . . . . . 5,764,800
Kâma (astal) . . . . . . . 282,475,249
Sthûla (physical) . . . . 13,841,287,201
It seems probable that electrons are astral atoms: for it is
stated by scientists that a chemical atom of hydrogen contains
from 700 to 1,000 electrons, and a chemical atom of hydrogen
contains the equivalent of 882 astral atoms. This may be a
coincidence, but that seems unlikely. Scientists thus appear to
be disintegrating physical matter and discovering astral matter,
though they will naturally think of astral matter as being a
further subdivision of physical matter.
Bishop Leadbeater, from whose writings the above is quoted,
does not know whether such disintegrated physical atoms re-form
themselves, but when, by an effort of will, the physical atom is
broken up into astral or mental atoms, it requires a continuation
of the effort to hold the atoms temporarily in those different
forms, and when the will-force is withdrawn the physical atom
reappears.
This, however, seems to apply only to the breaking up of the
ultimate physical atoms: when chemical atoms are broken into
ultimate atoms, they remain in that condition, and do not return
to their original state.
It should be noted that, although the atoms of any one
plane, the physical for example, are not made direct from the
atoms of the plane immediately above - the astral - yet, unless
the bubbles had had the experience of passing through all the
planes above, physical atoms could not be made of them.
The Hindu method of describing the process is as follows:
Each plane has what is called a, "tanmâtra" (literally, a measure
of "that"), and a, "tattva" (literally, "thatness" or "inherent
quality"). The tanmâtra is the modification in the consciousness
of the Logos: the tattva is the effect produced in matter by that
modification. We may compare the tanmâtras with the waves of an
incoming tide, which run up on a sandy shore, retire, and are
followed by other waves, which run up a little further. The
tattvas we may compare with the little ridges made on the sand by
the incoming waves, at the furthest line that they reach.
The idea is symbolised in Diagram XI.
Every atom thus has its "Thatness," the word ,"That" being a
reverent expression for the Divine Being. The measure of the
vibration of the atom, imposed upon it by the Will of the Logos,
is the Tanmâtra, the "measure of That"; this is the axes of the
atom, the angular divergence of which, within the fixed limits of
vibration, determines its surface form.
Thus the consciousness of the Logos is within each atom,
expressed within certain limitations, which we sometimes call
"planes."
The process of the creation of matter in successive stages
has often been described as the in-breathing and the outbreathing
of the Deity.
The existence of matter depends absolutely upon the
continuance of an idea in the mind of the Logos. If He chose to
withdraw His force, for example, from the physical plane - to
cease thinking it - every physical atom would instantly
disintegrate, and the whole physical plane would disappear in an
instant, like the light of a candle when it is blown out.
The ultimate physical atom has three movements of its own:
(1) rotation on its own axis; (2) motion in a circular orbit; (3)
a pulsation like a heart, a constant expansion and contraction.
These three movements are always going on, and are unaffected by
any force from outside. A force from outside - a ray of light,
for example - will set the atom as a whole moving violently up
and down, the amplitude of this movement being proportional to
the intensity of the light, and the wave-length resulting from
the movement of a number of atoms being determined by the colour
of the light.
Besides the force of the Logos, which holds the atom
together in its form, one of His forces is playing through it at
a number of different levels. There are seven orders of this
force, one of which comes into operation during each round,
working through what are called the spirillæ in the atom. For a
description of these spirillæ, as well as other details of the
structure of the atom, the students is referred to Occult
Chemistry (1919 edition, pp. 21-23, and Appendix, ii-vi.) .
In interstellar space - between solar systems - the atoms
are in the condition known as "free," lying far apart, and
equidistant, this seeming to be their normal condition when
undisturbed.
In the space between planets, however, they are never found
free: even if they are not grouped in forms they are subject to a
great deal of disturbance from cometic and meteoric matter, and
also to considerable compression from what we describe as the
attraction of the Sun.
From the above considerations, we perceive how it is that a
man in, for example, his causal body, could move freely in the
neighbourhood of a planet, where the atomic mental matter is in
the compressed condition, but would not be able to move or
function in far-away space, where the atoms remain free and
uncompressed.
To continue with our description of the building of the
solar system, we have now arrived at the stage where the vast
whirling sphere contains within itself seven types of atomic
matter, all one essentially, because all are built out of the
same kind of bubbles, but differing in their degree of density.
All these types are freely intermingled, so that specimens of
each type would be found in a small portion of the sphere taken
at random in any part of it, with, however, a general tendency of
the heavier atoms to gravitate more and more towards the centre.
The Logos next sends out, still from His Third Aspect, a
seventh impulse which, instead of drawing the physical atoms back
into Himself and dissociating them into the original bubbles,
draws them together into certain aggregations, thus making a
number of different kinds of what may be called proto-elements;
these again are joined together into the various forms which are
known to science as chemical elements.
The making of these extends over a long period of ages, and
they are made in a certain definite order, by the interaction of
several forces, as is correctly indicated in Sir William Crookes'
paper on The Genesis of the Elements.
The process of their making is even now not concluded:
uranium is the latest and heaviest element, so far as we know,
but others still more complicated may perhaps be produced in the
future.
As the ages roll on, condensation increases, and presently
the stage of a vast glowing nebula, usually of incandescent
hydrogen, is reached. Various other systems in our universe are,
of course, now passing through this stage, as may be seen by
means of any large telescope.
In our own case, as the mass cooled, still rapidly rotating,
it contracted and flattened until eventually it became rather a
huge revolving disc than a sphere. Presently fissures appeared in
this disc, and it broke into rings, presenting somewhat the
appearance of the planet Saturn and its surroundings, though on a
far larger scale.
As the time drew near when the planets would be required for
the purposes of evolution, the Logos set up at a chosen point in
the thickness of each ring a subsidiary vortex, into which a
great deal of the matter of the ring was gradually collected.
The collisions of the gathered fragments caused a revival of
the heat, the matter being reduced to a gaseous condition,
forming a glowing ball which, as it cooled once more, gradually
condensed into a physical planet fit to be the theatre of life
such as ours. Thus were all the planets of our system formed.
In this particular part of our system, however, the physical
planet which was formed was, not the Earth, but the Moon. For a
reference to Diagram V will show that the first physical planet
appears in the third chain, and that planet, in our Scheme of
Evolution, was the Moon.
When the active life of the Moon, in the third chain, was
over, a new vortex was set up, not far away from the Moon, and
the rest of the matter of the ring was gradually gathered into
it. The resultant collisions once more produced a ball of glowing
gas, which enfolded the body of the Moon, and very soon reduced
it to a similar condition.
As this combined mass gradually cooled, condensation took
place round the two vortices, but by far the greater portion of
the matter was attracted to the new vortex, which became the
Earth, leaving the Moon a much smaller body than it had been, and
altogether denuded of air and water.
The Moon was still, from the intense heat, in a plastic
condition, like hot mud, and the Earth in its earlier stages was
subject to the most tremendous volcanic convulsions. In the
course of these, enormous masses of rock, often many miles in
diameter, were thrown up into space, to vast distances in all
directions.
The majority fell back on the Earth, but some of them struck
the Moon while still in its plastic condition, and produced upon
it many of those huge depressions, which we now call lunar
craters. Some, but not many, of the lunar craters are, however,
really volcanic craters.
The Moon is at present like a vast cinder, hard but porous,
of a consistency not unlike that of pumice-stone, though harder.
Scarcely any physical action of any sort is now taking place upon
its surface. It is probably slowly disintegrating, and it seems
that in the course of our seventh round it will break up
altogether, and its matter will be used (with, presumably, some
of that of the Earth) to build a new world, which will be the
only physical globe of the fifth chain of our Scheme of Evolution
(vide Diagram V). To that new globe whatever remains of the Earth
will act as a satellite, just as the Moon now Serves the Earth.
In Theosophical literature, the Moon has often been
described as the eighth sphere, because it is not one of the
seven planets of our chain upon which evolution is taking place.
It is therefore a "dead end," a place where only refuse gathers.
It is a kind of dust-heap to the system, a kind of astral
cesspool, into which are thrown decaying fragments of various
sorts, such as the lost personality which has torn itself away
from the ego (vide The Causal Body, p. 183).
Now that we touched on higher planes it is important to note what is the actual scale of creation. All ancient sources as well as most occult newer ones agree on 7 great cosmic planes. Many misinterpret this to be 7 physical planes like this. In actually, the complexity is incomparably greater than that. Relevation for this comes from Bentov, a Hebrew mystic who was privy to be shown actually all the levels up to Godhead/Self.
You can see the scale in this presentation From Atom To Cosmos. It is HIGHLY advisable to watch if fully and carefully, of course, only if you intuitively recognize it's immense value. His model of the universe begins at 1:09:00
https://www.youtube.com/watch?v=-uUY0dPE-is
In short, here is the actual scale.
Our universe which is an egg of light + 48 other similar eggs placed on a great spiral of 7 levels makes one 'cell'.
15 of such 'cells' create one double tetrahedron structure, 1 cell on the bottom, then 3, then 7 in the middle, then 3 again and 1 on the top.
Great number of of such tetrahedrons make up one yet larger 'cell' 60 levels deep and these tetrahedrons slowly evolve out of the parent cell to one day create a new great cell of their own. And incalculable number of these larger cells make up the first COSMIC PLANE.
Scale continues in similar manner for the remaining 6 COSMIC PLANES which he did not describe. Ultimate level is the void, transcending time-space, merging with the Absolute Self, the only true reality.
https://www.google.com/search?q=fibonacci+spiral+galaxy
onepower
nix85
QuoteSpace is filled with ether indeed, somewhat less densely than around the planets, but ether does not dismiss the bending of time-space and relativity of time. Relativity IS correct. It is just his dismissal of ether in a sense of actual substance filling all space that is indeed incorrect.
To my knowledge space-time and relative time theories came about because of far off planets and inaccurate clocks. That is a planet very far away could cease to exist by the time it's light reached us letting us know it exists. It's basic astrophysics but then many had to drag in metaphysics because it seemed spooky. Next they had a problem with clocks changing time but instead of understanding that the material properties of the clock changed they created a nonsensical theory that time itself had changed, lol. I mean if your wristwatch was off would you think time miraculously changed?, it's absurd.
Quote"Spooky action at a distance", teleportation, instant communication over lightyears of distance is easily explained by higher planes of existence, two point may seem wide apart on our level but on higher plane they are right next to each other, speed of light, density of matter and rate of time flow all increasing by x49 on each plane above. We also know time actually stops on some astral levels so there are bands, but general rule is everything getting faster and denser x49 on each plane above. Ironically, denser means feeling less dense, higher energy level.
Most of these phenomena can be explained by basic Aether theory. We know that disturbances travel faster the more dense the medium carrying said disturbance. Just as an electron can travel faster in a conductor than an airplane can travel through air. The smaller the scale and the more dense the medium the faster a disturbance can travel through said medium. We also need to understand psychology and critical thinking to understand why so many come to the wrong conclusions. Let's be honest, many have created an imaginary world because they fear death. Creation, relative time, multiple dimensions and spooky phenomena all add to the illusion that we are immortal and more than we are. However if we take an objective third person perspective it becomes quite obvious were all a little crazy and misguided.
Think about that, imagine your another person looking down on yourself and objectively analyzing everything you do and think. It's not pretty, and most people find it a little disturbing so they try not to think about it. That's the thing isn't it?, were seldom if ever the person we think we are and most of what many believe isn't a reflection of reality. As they say in psychology, the only people who are truly crazy are the ones who think there not. In fact it was proven that the psychotic and insane have no mechanism for self-reflection or empathy.
In the big picture all the greatest minds in Free Energy rejected society and there false beliefs. They looked to nature because nature has no self-interest or beliefs and it is what it is. Nature is the ultimate reflection of reality not people and the crazy stuff they believe and do ...
As well all the greatest minds in free energy claimed the process was so simple even a child could understand it. Think about that, the theory wasn't complex, it did not require more and more complexity or imaginary beliefs but less. It's no wonder everyone fails at free energy because they seem to be moving in the opposite direction, lol.
AC
