Using Chas Cambel Flywheel System For 15 Horsepower
Started by thankGod, June 25, 2012, 11:57:43 PM
ARMCORTEX
So the trick of oscillating the pulley tension is called the aspen effect ??
I'm also designing a kinetic pulser mechanism.
Nice flywheels, they seem to turn nicely on the frame, you got those from scrapyard ?
TheCell
I only want to mention , that a Russian patent exists on this technology:
http://www.freepatent.ru/patents/2339844
Grumage
Quote from: ARMCORTEX on July 07, 2014, 02:45:07 PM
Dear ARMCORTEX.
No Harold Aspden discovered this......http://www.haroldaspden.com/lectures/30.htm
There might be something to his discovery !! ;)
The flywheels are borrowed from a couple of my Vintage Gas engines ( Gas in this case meaning Town Gas NOT Gasoline. )
https://www.google.co.uk/search?q=robinson+x+type+gas+engine&newwindow=1&tbm=isch&tbo=u&source=univ&sa=X&ei=LfK6U479F-vT7AainIHwCQ&ved=0CEEQsAQ&biw=1920&bih=943
Cheers Grum.
ARMCORTEX
I call this process ''smacking of the b****'' effect
I still dont know if the pulsing system should be isolated or not, or in the same system as the bigger wheel.
Ideally both wheels should have most their mass @ the rim, my smaller wheel is made up of a few solenoids @ the rim and I select appropriate timing via a bit of wizardry.
This is he technique I wanna try.
I provide energy to motor, wich is about 80% efficient, I load up a flywheel and have some pulse impact via solenoid.
Solenoid can stick out 10mm in 3 ms, little energy, but metal cap has lots of stenght and transfer much energy very quickly.
This is type of trick that manet cant perform, it dont have all that unstoppable kinetic energy stored it, its like full capacitor zero impedance source
Tangantially... This is important. Ive seen people with pulse motors but force is not tangantial.
Some people say magnets are good pulsing mechanism too, but you need shielding and everything, cost about the same.
Apparently adding a little faster pulse to something thats already accelerating gives OU energy... Anyways, claims from resonant fractals are quite vague and lack a bit of substance, buts its starting point for design ideas.
ARMCORTEX
So I researched this ''aspden effect'', not really  any clues.
But Chas opened to the door.
Now, we must play games with what I call ''eccentric kinetic transistor''.
Basicly a motor or flywheel system can lock itself to a system by turning a eccentric reflector that has a bearing @ the tip, thus tensionning the pulley.
Create a free-run/ connect scenario.
Use the ''smack my b*****'' up effect
I can almost see the puzzle unraveling now.
