Simple to build isolation transformer that consumes less power than it gives out
Started by Jack Noskills, July 03, 2012, 08:01:10 AM
Jack Noskills
Don't use the capacitor. If your coil is high impedance then it will work without caps. I have tried higher frequency mods using caps but cannot say about the results for sure because I don't have scope. High impedance means that when load is not connected idle current should be as low as possible.
Can you make measurements, using scope or meter ?
Using isolation trafo in front would be good to have so you could check testcase 3 what is going on there.
I don't understand what the heck is rasor only socket transformer.
color
Diode skill is a kind of additional service obtained from Jack Noskills.... 8)
It is very inconvenient for sincere members to study to leave the cafe because of the disease of this cafe... 8)
