please reproduce
Started by Murfedit, July 18, 2012, 06:09:55 PM
Murfedit
Aloha i stumbled onto an interesting thing.
Made a chamber for igniting small strips of magnesium two alligator clips inside one holds strip too be burnt,  the other holds a piece of copper and magnesium not touching each other separated at the end by air. Then i ignite the one piece of magnesium.  Smoke fills the chamber and coats the metals in a layer of carbon and i guess magnesium particles. Then i take readings and well if you do this you will see. Voltage and resistance readings. Haven't measured for amps yet.
Then i collected the magnesium ash and sandwiched it between two magnesium pieces and got a volt something.
It would be much appreciated if i could get some feedback on theory.
As it goes against most all classic battery theories.
Mahalo Aloha
Murf
Murfedit
Murfedit
Now I'm using the magnesium ash as the electrolyte. Between the copper and magnesium. 1 volt on my digital nothing on my analog voltmeter. increase in voltage but get no resistance or amps yet trying lots of variations though.
God i hope i don't have a problematic digital volt meter. It seems to give correct readings on regular 1.5 volt AA.
Aloha Murfedit
An interesting experiment. How do you figure that your findings so far go "against most all classic battery theories"?
(When you short the leads of your DMM on the most sensitive DC voltage range, you do get a reading of zero, I hope? And you get some millivolts when you just hold the leads, separated, in your fingers?)
mscoffman
Mufedit,
A DVM cannot measure the resistance of a voltage source, because the DVM has a battery inside
which is itself supposed to be the only voltage source. The DVM is aligned to it. So a DVM can only
measure the resistance of  passive resistors. What you need to do is to apply a load resistor and measure the current
and the voltage in one go. If you multiply the current times the voltage then tune the load resistor for where the
calculated power is maximum, you know that the impedance of the battery is equal to that resistance where the power
is maximum. This is because maximum power is transferred when the impedance of the source is
equal to the impedance of the load (resistor).
I can't really say where the carbon comes from, unless it is from the ignition source, the black may be magnesium oxide?
:S:MarkCoffman
