Thermoelectric generator - candle and cold water
Started by conradelektro, August 16, 2012, 07:23:38 AM
Magluvin
Have you ever seen my "orbonbon' ? lol  It is a solid state orbo. The first actually.
I named it all funky because of the way you named the orbette. It was just the thing to do at the time. ;]
I have a long ferrite toroid, the kind that is used as suppressor on computer monitor cables, wound as a long toroid, neatness inside was critical because magnets go inside, and I have a pickup winding wound around the diameter.  We insert the stack of 1/4x1/8in neos on the core. The N and S poles are attracted to the core, so most of the flux is in the core and within the inner side of the pickup coil.
When we energize the toroidal winding, the core goes into the Orbo effect, and the magnets field is released, and their lines of force cross the pickup coil causing current to flow. Then when we release the toroid coil power, the flux crosses the pick up again causing current in the opposite direction.
This is as a whole is inserted into a larger set of toroids as seen in the vid to contain the expanded field of the mags beyond the pickup coil when the orbo effect is engaged. So the flux switches back and forth from the inner core to the outer core, and generating currents in the pickup along the way.  ;]
I have several vids on it. This was the last one I did.
http://www.youtube.com/watch?v=KSgGFzfDiYE&list=UUjjcpZL8tkpn4WGkU2y_lPQ&index=10&feature=plcp
MaGs
Magluvin
Ok, just watched my vid, its been a while, and this vid doesnt use the outer core. The previous vids to that do.  It works wither way.  there were reasons for and not.
MaGs
anandml
How to make thermoelectric generator without thermocouple module or peltier cooler I mean direct conversion of heat in to electricity with some material parts
Magluvin
Anan, do you mean you want to make your own module instead of buying one? They are not expensive.  ;]
Here is a pic of the SS A/C unit.
MaGs
Pirate88179
I used to see those modules in surplus places all the time for a decent price.  I have not seen any for a while now.  Do you have a good source Mags?
