Richard VIALLE's new theory about negative mass and overunity
Started by Pascuser, August 28, 2012, 07:03:17 PM
Khwartz
Quote from: Atommix on February 27, 2014, 01:54:00 PM
I do not wish to put a negative cloud on anything but this thread is about negative mass and it is very important .
The other point is the error of personal petty politics of the mind set that says this is mine and that is yours ? Knowledge is not owned or controlled and must never become a theory .
There is only one universe it is this one ! I except that humans want to find the truth and claim it as there's so to climb up the ladder and begin to glow like a light house
illuminated by self . mmmmmmmmm I have pondered along the threshold of truth and see only one truth .
When the one is made of the many it is then that the real truth becomes a bell that rings its vibrations in the minds of all that think .
Also many walk down the path and straight into a dark wood where the only light that shines is in there head and continue to get lost in the darkness of self . So no I will not follow your advice or your theory for it is already lost in the wood.
Dont take that personal just except that a theory is just a theory and fact is a reality ! If an angel were to find you in the dark wood and taped you on the shoulder and stop you are lost deep in the wood and said follow the light and you will find fact not fiction . You would say but it is not the light I see in my head and continue to follow it until the end of time.
I am that angel ! and your theory is taking you deeper into the dark wood ! so please continue and I will keep watch over you and from time to time I will hit you on the head with my magic feather and tel you the truth.
There are masters and time lords demons and angels Aliens ghosts dimensions and the fabric of space in these woods do you think you will re-invent its reality ? NO !
GOOD LUCK
Atommix
Indeed, this thread was about negative mass too but we focus on the VG and Richard's theories.
You looks like having deep understanding and large views. PLEASE, open a new thread, like "New Ideas On Negative Mass, by Atommix", so that other guys here could focus on your own ideas, work and test them.
Here we test Richard Vialle's ideas. You have differents, so that's VERY GREAT, but not here please, Atommix, so that visitor could follow easier the thread.
Best regards,
K.
Khwartz
Translation of the
4th Q&A of the present FAQ of the website on the work of Richard
*** HOW TO GET "NEGATIVE POWER"? (Power produced by the input itself of the device, feeding back the power supply system, batteries, etc.) ***
http://richard-vialle.info/
(In agreement to the licence terms of the website, already published and taking no liability for any error of translation or modifications in between of the original terms of licence or of the original terms I translate here. These warnings applies to any writting by me on this website. )
Q : A quel moment puis-je obtenir "de la puissance négative" ?
• Q: At what moment may I obtain "some negative power "?
R : La puissance négative s'obtient lorsque les éléments suivants sont réunis :
• R: The negative power is obtained when the following elements are combined:
1/ Le système est conçu suivant les caractéristiques calculés dans le fichier Excel  :
Fichiers:
Feuille de calcul des paramètres pour l'autogénérateur de Richard Vialle Version:17.09.2012
http://richard-vialle.info/index.php/telechargement/finish/4-systemes-experimentaux/24-feuille-de-calcul-des-parametres-pour-l-autogenerateur-de-richard-vialle
• 1/ The system is designed according to the characteristics calculated in the Excel file :
Files:
Worksheet of the parameters for the autogenerator of Richard Vialle Version:17.09.2012
Ce document vous permettra de calculer les paramètres relatifs au générateur de Richard Vialle.
Licence Creative Commons  Date 2012-09-22 Taille du fichier 35 KB Téléchargement 725
• This document will allow you to calculate the parameters relative to Richard Vialle's generator.
License Creative Commons Date 2012-09-22 Weight of the file 35 KB download 725
2/ Un signal alternatif est injecté dans les spires qui entourent le barreau de cuivre. Ce signal doit correspondre à une fréquence qui se situe aux alentours de la fréquence calculée dans le fichier mentionné plus haut
•  2/ An alternative signal is injected in the coil which surround the copper bar. This signal has to correspond to a frequency which is located near the frequency calculated in the higher mentioned file.
3/ La "sortie" (la sortie du barreau de cuivre) doit être accordée, c'est à dire qu'un circuit d'accord RLC est positionné en court circuit afin de relier les deux sorties du barreau. Celà permet alors de faire sortir la puissance suruniaire du barreau et de provoquer la génération de la puissance négative qui se propagera alors au travers des spires (et donc à l'entrée)
• 3/ The "output" (the output of the copper bar) has to be tuned, that means a RLC tuning circuit is positioned in short circuit to connect both outputs of the bar. This allows then to get out the overunity power of the bar and to cause the generation of the negative power which will propagate then through the coil (and thus in the input).
Wishing this could help,
Best regards,
K.
Khwartz
Hello tim, how it's going for you, did you get what you needed to go forward?  Did you acheive o.u. on the bar? For my own concern I have achieved o.u. "global COP" on my own activity (see our MPs) the first week of March but need to be continued ;)
Nice to see you soon back,
Bedt regards,
Khwartz.
PiCéd
They talk about negative energy (apparently) on a certain frequency and some other things, so it must be the primary changing of sign, if so when they use a good battery as a primary energy it must recharging.
It is like two batteries set in a circuit without other component, one in one sens (+ to -) the other in the other sens (- to +), the battery who have the highest voltage recharge more or less slowly the less charged.
Khwartz
Exactly, PiCéd: if you read the previous pages you will see infinite recharging batteries is reported having been achieved in a private and industrial electronics laboratory :) and this, even feeding a load in o.u. two, at the output of the bar! :p
Thanks for your interest :)
B.R.
K.
