Richard VIALLE's new theory about negative mass and overunity
Started by Pascuser, August 28, 2012, 07:03:17 PM
tim123
Thanks Khwartz, and Verpies, for your clarifications... :)
e2matrix
Does anyone know a source for solid copper bar as described for making the U-coil?   Most copper bars for making house electrical grounds are actually steel with a copper coating.
Khwartz
Khwartz
Quote from: e2matrix on February 11, 2014, 04:25:41 PM
Hi dear e2matrix.
If you have a look at page 8:
http://www.overunity.com/12639/richard-vialles-new-theory-about-negative-mass-and-overunity/105/#.UvsHpctKHqA
You will see it is copper pipe.
It has been observed that solid bar doesn't give really more power than a pipe. And U shape bar with copper pipe have been the most replicated with success and the best known in terms of results.
For 1rst step, looks any material and shape will do. Even air! Lol (if the metallic connection plugs are inside the extremities of the thou air-coil.
For step 2, could be better to not have too large insulation on the bar but wires can be plastic insulated like normal wires for home power.
For step 3 could be better as thin as possible layer of insulation on copper pipe and enamelled wire.
You will see page 7, the specifics:
http://www.overunity.com/12639/richard-vialles-new-theory-about-negative-mass-and-overunity/90/#.UvsH1stKHqA
B.R.
K.
e2matrix
Khwartz,  Thank you - that is very helpful.   I'm glad pipe works well as I already have some 1/2" copper pipe.   I've also got a big coil of 3/4" copper pipe - probably 30 to 40 feet of it rolled into a flat pancake coil.   That might make an interesting setup and I think I've got enough insulated wire to wrap it.   But I'll probably stick to the more basic design for starters.
